Old 07-20-2005, 08:32 AM
Mecom Racer's Avatar
Mecom Racer Mecom Racer is offline
Default Cable-X calibration question: T56 "gear" teeth?
Okay, I'm ready to set up my Abbott Cable-X but I'm a bit confused about something.
The formula to set the dip switches is as follows:
Transmission gear (#of teeth) X axle ratio X tire revs/mile = pulses per mile
The pulse per mile is compared to a chart and the switches are set accordingly...
My question is: Since the T56 has a VSS instead of a standard speedo gear, what number do I use for # of gear teeth? From my research I learned that the T56 has a 40 tooth reluctor wheel (40 pulses per driveshaft rotation). Would that be the number I use?
40 X 3.45 X 734 = 101,292
Would this be right? What have others used to calibrate their Cable-X?
Thanks.
"Well, the trouble with our liberal friends is not that they are ignorant, but that they know so much that isn't so." -- Ronald Reagan
http://photobucket.com/albums/v494/M...ort%20Tribute/
Old 07-20-2005, 10:16 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Sorry I can't help.
But can you give me product and pricing info on this unit. I priced one out awhile back, not sure if it's from the same company though. I think it was around $300.
Old 07-20-2005, 12:32 PM
Sounds about right. I bout it a long time ago. I'd have to go dig up the receipt.
FYI, I called Abbott and they said it is 40 teeth.
