Old 02-12-2008, 10:18 AM
InMotionJosh InMotionJosh is offline
Default Air Ride Sway Bar Endlinks!!
I want to start by thanking Darren over at Air Ride for getting me a set of these new endlinks that they will be selling.
I have a full air ride setup on my car and had the standard sway bar end links on there. Darren got me a set of their new endlinks that are flexible. Here are a couple pictures with the car raised up and lowered down.
Old 02-12-2008, 11:28 AM
GMracer's Avatar
GMracer GMracer is offline
looks good Josh, didn't know you were over here, where are the rest of the pictures of your car located, haven't see it since you got it powder coated.
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 02-12-2008, 11:47 AM
Here are some progress pics. Working on shaving the body and fire wall now. Stainless hardline to all the bags and brakes, got a new LS2 crate motor sitting on the stand and getting a cam tonight, 4l80 being built right now, gonna paint it all and drop it in soon.
https://lateral-g.net/forums/showthread.php4?t=11403
Old 02-16-2008, 10:25 AM
frankenstang frankenstang is offline
How much for the links? Last I looked, There wasn't a price on the site.
check out pics of the car at www.fquick.com/frankenstang
Old 02-18-2008, 01:28 PM
darren@ridetech's Avatar
darren@ridetech darren@ridetech is offline
$149 for the set. $325 for the PosiLinks with the MuscleBar.
Old 02-18-2008, 04:05 PM
Tony, are they height adjustable? I need pretty long links for the 91 Fox Mustang I have. At least longer than the picture posted above.
Old 02-19-2008, 05:49 AM
Tony@AirRideTech Tony@AirRideTech is offline
Supporting Vendor
Yes....... you can actually buy the end links seperate (in both straights or 90's) and you can make your own connecting 12MM rod. Cool thing about that too is that you can also bend your center rod to help compensate for gross missalignment.
Old 02-19-2008, 07:49 AM
parsonsj parsonsj is offline
Neat stuff. My heim joint endlinks are on the hairy edge of binding at full bump and rebound. Maybe I need a set just to see if they work better...
jp
John Parsons
