Old 06-03-2008, 11:41 AM
silver86 silver86 is offline
Originally Posted by CraigMorrison View Post
I'll see if we have done one of these before. Could probably do an ifs front (not MII) and 3-link rear for you..... Because of track width it would more than likely be a manual steer setup though.
I was looking into the AM IFS kit...I am really leaning toward going with the Morrison IFS weld in crossmember kit. I saw that it is listed with a track width of 48 on a 22" os/os frame. The original Track width of my healey is 48.7", I went out and measured my frame, it is 23" from os to os. I dont know if you would have any suggestions as to what direction to take this. I can either try to add 1" in the crossmember or order the one for the 28" frame and narrow it 5".
What would you suggest?
Thanks!
Old 06-03-2008, 06:09 PM
frankenstang frankenstang is offline
With the AME kit, we lose the OEM front x-member right? It's 'self contained'? If so order the smaller one and it gives us a tad more room for wheel offset. Does the AME part have engine mounts? I don't think it does, we have to make some anyway.
check out pics of the car at www.fquick.com/frankenstang
Old 06-03-2008, 07:48 PM
We will loose the front x, yes. No big deal, the original is actually even with the bottom of the frame, it doesn't hang below it. The KIT is just the x member and lower/uppers ect..Here is the kit 2nd one down http://artmorrison.com/layout.php?y=.../mifs/&x=index
We will still use the existing "boxes" for the engine mounts, that wont be a issue. We will just cut them down a few inches and weld a plate on it.
If we order the smaller one then we either need to notch the frame 1/2" on each side or we will need to add 1 " to the x member. I don't really think it will be that hard to notch it and box it, I just wanted to see what they suggest, they might even be able to make one for me.
I am almost positive I am going to get the AME kit though, seems to be the easiest way. They also come the closest in the track width we will need.
