Old 08-17-2008, 10:59 AM
brownz brownz is offline
Default MOSER 12bolt with ford style bearings ?
The question is does the bearing sit flush with the rear end? I would think so but when i install the axle the bearing will not go all the way into the tube, its about 3/16 from being flush and thats what i need for the c6 zo6 brakes to clear the backing plate for the e-brake, this has been a mightmare from the start
Brandon
Old 08-17-2008, 11:12 AM
Avgasman's Avatar
Avgasman Avgasman is offline
Sorry to say but it will not sit flush with that housing end. You'll either need to open the ID of the disc brake bracket , and then create a retainer with a stepped lip to hold the seal/bearing in place OR you could machine a relief into the disc brake bracket to clear the protruding seal. you might want to add some material on the other side of the bracket to ensure at least .250 of bracket is holding everything in. I can post some pics if it will help.
Dan
1969 Chevrolet Camaro
DSE/SDPC-LS7/T56/FORGELINE/BAER/VAPORWORX/
/DAKOTA-DIGITAL/RECARO/MOMO/
/MSP-FAB/BLACKTECH/
Old 08-17-2008, 12:19 PM
ya some pics would be great thanks for the info
Brandon
Old 08-19-2008, 02:45 PM
Avgasman's Avatar
Disc brake bracket with a 3.150" hole:
Retainer with a .110" stepped lip:
Bracket and retainer assembled:
Dan
/MSP-FAB/BLACKTECH/
Old 08-19-2008, 03:18 PM
68protouring454's Avatar
yes most bearings have either a .105 or a .120 lip, thus needing a spacer to use with the retainer so when tightening you do not bend bracket.
tobin at kore 3 can get you a spacer you need
Jake's Rod Shop
Old 08-20-2008, 04:54 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Doea anybody know the part number for the outer seal? I have a moser 12 bolt and big ford ends as well. I screwed up my seal taking the axle out tonight.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 08-20-2008, 06:39 PM
outer seal? the bearing is sealed, and has a collar that locks in on in place, then there is a inner seal that press's in behind the bearing race.
seal# 15141 napa or anywhere can cross this number. i just put a new axle seal in today, in my moser 9 inch with the 12 bolt/9 inch bearing end
Jake's Rod Shop
Old 08-20-2008, 06:56 PM
Avgasman thanks for the pics
Old 08-20-2008, 08:24 PM
Avgasman's Avatar
No sweat, about time I do something productive!
Dan
/MSP-FAB/BLACKTECH/
Old 08-21-2008, 03:20 AM
bigtyme1's Avatar
Thanks Jake.
69 RS Ragtop
[email protected]
