Old 09-07-2008, 01:18 AM
Originally Posted by W5 406ci View Post
This is my project mopar for the 2009 power tour 1964 Plymouth valiant
W5 R block 385ci/viper t56 6 spd
mini tub/dana 60
The last pic is when I brought it home and took the drive train and interior out 65,000 original miles
Cool project....start you own thread under project updates.
Old 09-07-2008, 01:22 AM
monza's Avatar
monza monza is offline
So please sum up how was the whole Hemi install compared to a LSX in a older car?
or
Should my question be how was it dialing in a Hemi in a old Mopar compared to installing a LSX in a Chevy?
Same, better, worse, or just new and different and climbing on the learning curve?
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 09-07-2008, 06:45 AM
Blue70's Avatar
Blue70 Blue70 is offline
Originally Posted by Datsbad View Post
yes , just go directly to our website and you will see pics inder the gallery.
I'll go check that out right now, thanks!
Old 09-07-2008, 07:06 AM
Blue70's Avatar
Wow, I was more interested in the front suspension,
but I really do like that rear setup that you have on there!
Old 09-07-2008, 04:15 PM
Datsbad's Avatar
Datsbad Datsbad is offline
or
Well with the chevy you have motor mounts and a crossmember, on this set up it took all new suspension to pull it off the right way .
You can use the factory Mopar suspension but there are a few more little things to address when doing that . I couldnt have it that way as I did not want torsion bars in it anymore.
The LS is much cheaper. On the Mopar you have to changethe PS pump since the factory is a much higher pressure. LS you can use stock .
Mopar electronics just plain suck, so the option if doing a factory computer was out for me. That leaves a big dollar wiring harness and stand alone computer. AEM engine management and a cable TB was about 4k compare to a similar set up with GM using a stock computer would have been about $1000.
The 5 speed set up was also much more at $5500 to get it in the car correctly. LS would have been much cheaper.
As far as the work its about the same and no big deal really, just the exspense caught me off guard.
I often joked that I should have put a LS engine in the DEMON.
I will say that I am VERY impressed how the stock 6.1 Engine runs with a stick and a good exhaust system. The car is light and you can really tell.
I plan to run it at RTTH on the drag strip to see how it does. I predict about 90 mph 1/8 runs. I think that would put it in the high 11's low 12's somewhere.
The car is like a go cart , precise handling . I am really in love. I just put in some 3 point seat belts and belts in the back for the kids. I plan to use this everyday rain or shine. What fun is it to have these cars and not drive them , right???
It probably will cost less to drive that my Diesel Dually.
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 06-07-2013, 12:06 PM
W5 406ci W5 406ci is offline
Car plymouth
Old 06-07-2013, 12:11 PM
cascius cascius is offline
Car plymouth
The Demon was made by Dodge. Plymouth's version was the Duster.
