Old 09-21-2008, 06:29 PM
Dukeofsho's Avatar
Dukeofsho Dukeofsho is offline
Originally Posted by scherp69 View Post
Prodigy Bar, Air Bar or Alston G-bar (the air bar does not allow for any adjustment) all use coil overs and will bolt on to your existing frame rails. It's recommended that you weld in though.
I have had problems with just bolting the on. I intalled an airbar system on a Gen I camaro and had it brake loose. It sheard a couple of bolts off. My thoughts are the the frame rails were a little thin and the bolts worked them selves loose. I later found out the the original frame rails were "ground down" to remove rust and scale by the owner. Then painted chassis black. Doh! Now I weld every system in. If you ever wanted to go back to the original suspension the stitch weld could be cut and ground down.
