Old 09-23-2008, 06:30 PM
We are working our way through the supplier issue. Getting it all in house now.
We are setting him up with a complete 480HP LS3 / 6 speed package and for a LS application to 500HP, the GTO 6 speed works well and is born to be behind the LS motor. Only reason I suggest it in this application. We can use all GM stuff, have OEM quality, and actually beat the cost of the TKO.
Frank Serafine
Old 09-25-2008, 10:09 AM
AJSZR2326 AJSZR2326 is offline
if i remember correctly the t-56 used on corvettes , ect. will need a tranny girdle if you go over 500 hp
Old 09-25-2008, 11:20 AM
The WidowMaker's Avatar
good to hear frank, youre raising the bar every day.
"The WidowMaker"
