Old 10-17-2008, 08:38 PM
camaro2nv's Avatar
camaro2nv camaro2nv is offline
Default 68 Camaro Air ride??
I bought a 68 Camaro a few weeks ago. The car was blasted and painted. Being a paint guy the car is FAR from what I want. I want to build a pro touring car. I have many plans to mod this car from the ground up. Ive always wanted to build a Camaro but never had a chance. Ive modded many Cars, bikes they just turned into projects. I guess those projects were good for me because Ive learned a lot about modding. Now I just have to learn about 1st gen Camaro stuff. I have ideas running wild,lol. One of the main things is I want is a air ride system. Question is should I start with the stock sub frame and just mod the control arms ect. Or buy a subframe ready to roll, thoughts????
Heres my project
Old 10-17-2008, 08:39 PM
camaro2nv's Avatar
One of the many past projects
Old 10-17-2008, 08:40 PM
camaro2nv's Avatar
Ill try and dig up my bikes
Old 10-17-2008, 10:03 PM
Its all a matter of your needs, desires, and budget. What is important, and what is secondary. You have obviously done some killer projects, and like your previous projects, planning is everything! Putting together a budget, selecting the components, and staying with the plan is the only way to go.
Too many projects get started and don't get finished because they blow the budget, or plans change mid stream causing a blown budget. These sites are litered with these projects.
Make a plan, fill in all the blanks, and then build.
Frank Serafine
Old 10-18-2008, 01:03 AM
camaro2nv's Avatar
Thanks Frank. I just placed my first order with you. Im sure there will be many more,lol.
BUDGET oh do I know about a budget. That car posted above got way out of hand!! I hope to have a budget of 30k plus the car. Keep in mind Ill be doing ALL the work myself, paint motor ect.
Back to Suspension. I would like the bling of a new subframe. BUT the car wont see a track. The goal is to have something modern and that performs good as a street car. When parked I want to lay it out. I want BIG brakes Any suggestions?
Old 10-18-2008, 10:37 AM
rich-allen's Avatar
rich-allen rich-allen is offline
I just bought a 6 piston willwood kit from Rodger at Ironworks. I think it was around 20% ofF list.
Not cheap but killer brakes!
67 RS/SS
Old 10-18-2008, 10:52 AM
Air Ride is the way to go for you. No need for a aftermarket subframe. Some of the baddest Pro Tuouring cars around run Air Ride.
For brakes, bling for the buck, our Prodigy Customs Total Car G Machine Brake Packages are hard to beat. You get everything you need all the way down to the fluid and special tools you need. Your doing this yourself right?
As with almost everything else you will need for the car, we have both these products.
Frank Serafine
Old 10-18-2008, 11:16 AM
camaro2nv's Avatar
Perfect, Yes ALL work will be done myself. Do you have a link to the brakes? What about the rear end? Ive been reading up on the G bar. Do you guys sell it? I dont have a lot of knowledge about parts for this car. Im trying to learn as fast as I can . Thanks for the help guys!
Old 10-18-2008, 12:27 PM
rich-allen's Avatar
I'm running the G-bar (the original one) and it's pretty good. Most here will agree when I say the DSE kit it much better, here is a link. http://www.detroitspeed.com/productp...uadra_prod.htm
Frank sells an upgraded kit for the G-bar and a lot of guys are running that too.
Either way you should be fine.
Rich
67 RS/SS
Old 10-18-2008, 12:37 PM
rich-allen's Avatar
I forgot to mention that I'm running my stock subframe as well.
I didn't go with Air Ride but I did replace everything else with aftermarket.
So Frank is right, you don't need an aftermarket SF however, the ATS subframe kits are smoking bad ass!~
67 RS/SS
