Old 10-28-2008, 07:13 PM
awr68's Avatar
awr68 awr68 is offline
Chris I like the top wheel, but wouldn't do full polish. I see the center section darker or machine finish.
Tony
'68 Camaro
Old 10-28-2008, 07:25 PM
akrapovic's Avatar
akrapovic akrapovic is offline
I think you should go with the G cubes.
I'm a little biased.
Old 10-28-2008, 07:40 PM
brans72 brans72 is offline
X2 Rushforth wheels
Old 10-29-2008, 03:04 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Do you have a larger version of that picture?????
What size tires do you have there?
Old 10-29-2008, 06:10 AM
akrapovic's Avatar
The tires are 295/35/18 in the rear and 235/40/18 in the front. I'll work on a bigger picture.
Old 10-29-2008, 01:41 PM
redfire69's Avatar
Looks good! Like to see more pics too.
Ron
69 Camaro Redfire
Old 10-30-2008, 08:02 AM
akrapovic's Avatar
Here are some pics. I will post some after I lower next week.
Old 10-30-2008, 10:57 AM
69MyWay's Avatar
Okay guys...still hunting. Still like the G cube...but am now looking at other options. So...what do you think of these? Either set will cost me about $3,800 shipped with tires. These are much more than the Intro...but a whole other look too. Here is the lat-g link to the car.
https://lateral-g.net/members/mcdonald69camaro/
I think the black center would look Billy Bad Butt on this...while the silver center would be neat and clean. The car needs a new attitude that it just isn't getting with the C5 wheels.
Old 10-30-2008, 11:33 AM
slck6t9's Avatar
slck6t9 slck6t9 is offline
I like these two choice's better.
Old 10-30-2008, 11:40 AM
69MyWay's Avatar
Thanks man...
does anybody know the exact maximum size and offset you can stuff in there on a stock suspension?
I get a little rub in the rear under hard turning or hitting bumps when I have the rear seat full of people - not enough to be an issue with the stock rear 18" C5 wheels
The front rub when I turn at a decent speed, or if I go into a drive or some sort of bump up. I assume 7" rim in the front with a 235 40 18 might stop that...but in the rear I would like to keep it maxed.
I'm going back to a stock width rear axle - would like to go 10 x 19 on the rim...and am curious about back spacing.
