Old 12-03-2008, 06:31 AM
HaulinAsp's Avatar
HaulinAsp HaulinAsp is offline
Thanks for the welcomes guys!
I thought I was gonna be lonely here with all the Chevy folks.... Glad to see some Mopar folks.
I have a built up 70' 440 6-pak engine that was built up and modded with some ported Eddy Alum Heads and a Eddy Dual Quad intake, this engine has a lot of Jet Hot coated parts and was origonally destined for the Charger. Then after I gave up trying to find a replacement Viper V-10 engine for the SRT-10, and got a lot of momentum about the Cummins swap, I stepped into finding a un-used Viper block, so I couldn't walk away from it and decided to take my Charger to another level.
I am seeking out options on what I could do for the front and rear suspensions..... *I would like input from the pro's...
2004 Ram SRT-10/Cummins Conversion- Project RattleSnake
1966 Dodge Charger- Viper Powered Project
Old 12-04-2008, 02:49 PM
joe440's Avatar
joe440 joe440 is offline
this thing is going to be sick! looks great so far
Old 12-05-2008, 06:44 AM
HaulinAsp's Avatar
Thanks Joe
Old 12-06-2008, 07:54 PM
both will be very cool. I like those original chargers as much as the more popular later ones. The MOPAR freaks will hate you but you can always hang with us. Check out XV for parts and see if they have anything that will work for you.
Old 12-15-2008, 11:52 AM
HaulinAsp's Avatar
I started to prep some of the engine components.....
Stock Viper Valve Cover.....
I stripped the red paint off the Valve Covers, then smoothed them with a 3-M cookie, then some sanding block work, and finally glass beaded surface for primer adheasion......
I also started to smooth off the casting lines and casting flash on the intake manifold....
I will port and polish the cylinder heads and also port match the intake manifold ports....
