Old 12-20-2008, 08:15 PM
ttchevelle's Avatar
ttchevelle ttchevelle is offline
Default Which fuel pump?
Im running a tt ls1 75lb injectors 20 psi of boost intercooled. My question is I bought a aeromotive eliminator pump that will require a pump controller on the street. Should I stick with this combo or should I switch to a regular
A1000? My horse power goal is about 900-1000. Thanks!
Old 12-20-2008, 09:48 PM
camcojb camcojb is online now
I would run the controller with either of those pumps.
Old 12-21-2008, 07:27 AM
ttchevelle's Avatar
Thanks for the info. I would assume its best for the pump so it doesnt overheat right? Nice car by the way! Im in the middle of trying to find header fabrication in socal that will weld stainless alot of guys will only work with mild steel. How lony did your car take you to finish?
1965 chevelle ls1 twin turbo/th400/currie 9 inch
Old 12-21-2008, 08:45 AM
thanks. There's a day by day build thread here; just under three months including all the turbo fab, re-wiring the car, etc. Just me working on it, other than having a friend help with welding and fabbing the downpipes.
https://lateral-g.net/forums/showthread.php4?t=13736
Tom Nelson has a great guy down there for welding stainless. Here's the 321 stainless headers he built for me:
Old 12-21-2008, 12:40 PM
ttchevelle's Avatar
If you dont mind me asking whats the $$ for these headers?
Old 12-21-2008, 02:13 PM
you'll need to contact Tom at Nelson Racing
Old 12-30-2008, 07:23 AM
HWYSTR455's Avatar
HWYSTR455 HWYSTR455 is offline
Keep in mind that some ECUs/ECMs have controllers built in, and you may not need an additional controller....
1971 Lemans Sport 461 bottle fed daily driver
1971 Trans Am 474 blown EFI pro tour car
1972 442 W-30 clone
Old 12-30-2008, 01:26 PM
syborg tt's Avatar
Mark over at bent Customs can do some incredible work.
[email protected]
www.bentcustomandperformance.com
marty-mj
Old 12-30-2008, 06:56 PM
ttchevelle's Avatar
I am curious if a 2000 chevrolet camaro pcm for an ls1 has an internal controller for the fuel pump or not any ideas?
Old 12-30-2008, 07:49 PM
lil427z's Avatar
lil427z lil427z is offline
take a look at the weldon pumps.
rick k
