Old 01-13-2009, 01:37 PM
TT LS2 TT LS2 is offline
Default Rotissere Casters?
What type of pneumatic casters are you guys using? I'm fabb'n a rotissere and I need wheels. Any help would greatly be appreciated. Thanks.
Old 01-13-2009, 02:48 PM
almcbri's Avatar
almcbri almcbri is offline
I have some from harbor freight. They are 4". Make sure they are locking, that is one I thing I will fix on mine. I found myself chasing my car around the shop while grinding or working on it
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 01-16-2009, 12:15 AM
deocon deocon is offline
I used 10" pneumatic wheel at the rear and two solid rubbers up front.
To prevent the flat spotting of the wheels, I installed screw jacks to handle the weight of the vehicle once it has been mounted.
Old 01-16-2009, 04:35 AM
dhutton dhutton is offline
I used hard casters that I got from Northern Tool. If you use pneumatic casters make sure you can support it without the casters when you are working. Otherwise you will be surprised at the movement you get when you are working on the car due to the casters bouncing.
I think the only time you want pneumatic casters is when you are loading it on a trailer or going "offroad" while you sandblast etc.
Old 01-16-2009, 08:07 AM
elitecustombody's Avatar
I used Harbor Freight 8" hard rubber casters all with locks,Northern Tool has a good selection as well, it made such a big difference from little 4" casters,moving it with a car attached on smooth floor is a effortless ,also great when loading and unloading on the flatbed , I don't think you'd benefit much from pneumatic casters unless you like to push it around in dirt field or work on your car on the front lawn with plush grass
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 01-16-2009, 08:38 AM
OOCustoms's Avatar
OOCustoms OOCustoms is offline
heres a company i use out here in california. they are strictly a caster supply. they can assemble you any kind of caster with any load range wheel and with or without brake units. they asemble them on the spot and im sure they can ship them where ever you need. i wouldnt go anywhere else except for maybe northern tool. I have a set of iron casters one a milling machine cart that are coated with a 1/4 inch layer of a high end urethane or something that can hold like 1000# each and wont develop flat spots. they also have some hightech plastic ones that hold the same and are a little cheaper. give them a call you wont be disappointed.
Industrial caster and wheel 510-569-8303 located in san Leandro CA
Marc
Old 01-16-2009, 09:43 AM
Marc
FYI, Northern has identical casters as Harbor Freight and there is absolutely nothing wrong with HF casters as long as you use appropriate load rated casters for the job, i think I paid $17 a piece for 8" swivel caster with brake
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 01-16-2009, 05:06 PM
Marc[/QUOTE]
Thanks, Marc!
Those guys (Industrial Casters) are like five minutes away from my house!
They actually told ne NOT to do a pneumatic caster. I need a caster that will make an EASY transistion from a smooth garage floor to a roughly paved driveway to a flatbed while supporting my 69 Camaro shell. They rate each 8" caster at about 350 lbs. I was thinking if I used three 8" casters per side of the rotissere, that would be more than adequate to suppout the car. Right? people with experience, please chime in! I would hate to use hard plastic/hard rubber, due to the rough terrain that they would see.
Just my thoughts...
Old 01-16-2009, 08:43 PM
harbor freight casters I used with posted above pic are rated at 450lbs, so 450x6 is 2700
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 01-23-2009, 02:12 AM
OOCustoms's Avatar
well you can get the rubber tire casters there too cant you? im sure they have something that will work for you. if not if you do anything else id use them. they dont have cheap harbor freight stuff there. how rough it the drive way??
