You might want to but the plactics gaurds on the brake rotors that GM has. they said to use them when the wheels are off a ZR1. they say that they can chip easy and once that happens they are junk. just somthing that i read in the tech article that they send to the dealers. LOOK GREAT
EDIT found the GM service guide. it says that each ZR1 was shipped with one set of rotor protectors, they are blue foam pieces.you can get sets threw your GM ( chevy ) dealer threw GMSPO (general motors special parts order). or it says that you can geta 25.4mm (1in) foam pipe insulator can be used if you dont have a set of the protects. the protector should be slid over the rotor before the wheel is removed just in case the wheel may come incontact with the rotor.
