Old 02-07-2009, 02:19 PM
OldSchoolSS OldSchoolSS is offline
Default TCI 6X Six-Speed Automatic Transmission
Does anybody have any information on these yet? I saw an advertisement on it in the latest Chevy High Performance Magazine on page 55. I went to their website and couldn't find anything. It looks like it's based off of a 4L80E. It lists the gear ratios 2.97, 2.23, 1.57, 1.18, 1.00, 0.75
I wish they would have went with a deeper 1st gear ratio or a higher overdrive.
Does anybody have any idea on how much this thing is going to run?
Old 02-07-2009, 06:52 PM
chicane's Avatar
chicane chicane is offline
There is nothing wrong with those ratios...
Anytime you go past 0.75 in a final drive... the efficiency plummets. I think they chose great ratios for what this transmission is designed for.
Drop a set of 3.25-3.50ish ratio gears into the differential and you'll get the best of both worlds.
Old 02-08-2009, 03:29 PM
Neki67 Neki67 is offline
Bowler in combination with Twistmachine can help you with similar options, offer great customer support and sponsor this site and PT. I speak from personal experience with regards to Twistmachine.
When you do a little search on this forum and/or the PT forum you will find more info with regards to these products.
Old 02-09-2009, 03:31 AM
holschen's Avatar
holschen holschen is offline
Default video info
http://video.aol.com/video-detail/tc...008/3845253249
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
