Old 02-11-2009, 06:01 PM
g356gear's Avatar
g356gear g356gear is offline
Default Best aftermarket deluxe door panels..69 Camaro??
My original panels had dried out and cracked long ago and were repaired by a vinyl repair shop. Needless to say the repairs from 20 years ago are starting to come apart as well. Who has the best deluxe door panels currently available for the 69 Camaro that look and fit correctly?
Old 02-11-2009, 06:54 PM
dhutton dhutton is offline
My understanding is that the Al Knoch ones fit best.
Old 02-11-2009, 07:01 PM
I am pretty sure Al Knoch is the only manufacturer of deluxe panels and they suck the big one!
Frank Serafine
Old 02-11-2009, 07:24 PM
Musclerodz's Avatar
OER make them as well, stay away from those
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-11-2009, 07:27 PM
I put mine on and they do suck. Forget the clips and get ready to trim you but off. Mine ended up being to long and needing the front shortened .25 inch so the door would shut on the drivers side. Fit and finish is not great either. Are you sold yet? They turned alright.
Old 02-12-2009, 04:30 AM
I bought a set of OER panels. They looked like they were going to be a PITA to make fit. Luckily I found a nice set of originals on ebay a couple of days later. I sold the OER's on ebay, took a beating on them. At least the guy who bought them saved a bunch of money to justify making them work.
Old 02-24-2009, 11:05 AM
Josh69 Josh69 is offline
I've got ones made by Al Knoch from Year One. I swear they came in a box that said OER, but I may be wrong. I had to call Year One and they put me in touch with Al Knoch to verify that I rec'd Parchment and not Ivory.
Great, can't wait to deal with these.....maybe by the time I get my headliner in they'll be a breeze.
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
Old 02-24-2009, 11:17 AM
The ones I bought came in an OER box and the vendor that sold them to me said they were the same as Al Knoch. Someone told me the Al Knoch ones are supposed to have Al Knoch stamped into the back of them. I couldn't find it on mine.
Good luck,
Old 02-25-2009, 12:39 PM
JKnight JKnight is offline
I have a set that I bought from a guy on Ebay 2-3 years ago and they are horrific. They are at least twice as thick as the factory ones (I'm not exaggerating), and as a result, you can barely shut the door, the window cranks can't reach the stud, and some of the studs on the trim pieces can't make it through to the back of the panel.
They're also curved (warped). I paid $200, thought it was a great deal. Now I know why....
Edit: Ok, I went and measured and they're only twice as thick, but still, that's way too much to work.
Old 03-02-2009, 11:07 AM
JKnight, were you able to make them work? Mine also appear warped. I was hoping they would bend into shape on the door...they do seem thick. I had the standard interior, so I don't have a plan B. I put the deluxe regulators in, I hope they work or I'll be installing power windows. Argh.
I may need to break out the heat gun and try to straighten them out if necessary.
