Old 10-28-2005, 05:00 PM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
Default Partial front Suspension assembly
...or more of a mock-up really. I'm trying to figure out if I can get my ride-height set right from the get-go. I hope my calculations are somewhat accurate.
I partially assembled it with no height adjusters installed (just the 9.5" 700# AFCO springs). The crossmember sits 2.5" off the floor. Adding approx. 1750 pounds of sprung weight, will drop it about 2.5".
(700# x 2 = 1400#/inch)
1750/1400 = 1.25" compression
1.25 x 2 (because the lower ball-joint is 2x the distance away from the pivot) = 2.5" lower
2.5 - 2.5 = 0" cross-member to ground. (almost low enough )
The height adjusters are 2.875" high at their min. height.
2.875" x 2 (lever of A-arm again)= 5.75" clearance at the crossmember
WAY TOO HIGH!!!! That's almost stock height
I'm thinking I should cut 3/4" off the height adjusters, and get it down to about 4.25".
Here is some more eye candy
Old 10-28-2005, 07:56 PM
Roger Poirier's Avatar
Roger Poirier Roger Poirier is offline
R & D will pay hugh dividends in the end. The math doesn't always work out. Make sure your engine is in and the body is on. I had to go with 18" up front with 20's in the rear to receive a 1" difference in the frame height. I also used 3" lowering springs all the way around. Don't forget the additional space needed for proper header clearance.
R.P.
official car name - DELIVERANCE
Old 10-29-2005, 06:25 PM
coolclassiccars's Avatar
coolclassiccars coolclassiccars is offline
well said roger cut nothing till you are alot closer to a complete car,the last time i cut for appearence, no front sheet metal on the car , those springs are now shop springs. the headers were on the ground.
Old 10-29-2005, 06:48 PM
Derek69SS's Avatar
Cool
Cutting from the adjusters won't be a problem, I will still have 2.5" upward adjustment at the springs, equating to being able to adjust the ride height 5" upward. Worst case-scenario, I'll need to dissassemble the front end, and raise the adjusters up if I cut too much off.
Old 11-03-2005, 12:45 AM
conekiller13's Avatar
conekiller13 conekiller13 is offline
Looking at that top picture it looks like have serious camber gain problem. I know My car sitting like that with no springs and the lower arms bottomed has all negative camber and no positive...............are you using tall spindles? Aren't You concerned about those adjustable upper arms changing Your camber curve as You adjust for static camber and caster? How do know when they are the "right" length for geometry? Just curious.
Dan
Old 11-03-2005, 07:17 AM
sinned's Avatar
sinned sinned is offline
Dan, he's going to gain negative. What's wrong with that?
The arms won't affect the curve; only the geometery as a whole.
Dennis
Old 11-03-2005, 07:49 AM
Derek69SS's Avatar
In the top pic, the upper arms are threaded out to get the spindle to sit straight up on purpose... the reason is, I didn't have any spare lugnuts handy, and that was the only way I could get the wheels to stay on using only gravity
My main concern at this time is figuring out my ride height... overall, I'm looking for a great performing setup, but I don't have the experience or know-how to set it up to its maximum potential, nor will I ever push it hard enough to need it set up that way. I just want a suspension that can outperform what I will have the cahones to push it to.
One day I may want "more" out of it, and the adjustable uppers allow me the ability to set to the exact length I want them.
Old 11-03-2005, 07:57 AM
protour's Avatar
protour protour is offline
5.75 is no where close to factory height.... My front CM is 5.75 off the ground and with our crappy roads(Alberta) I had a few problems with my exhaust last year. I'll try and load a pic for ya.
-Matt
72 Chevelle. 370ci LS, Forced inductions S476, SpeedTech Suspension equipped, C6 Z06 brakes
Old 11-03-2005, 08:00 AM
protour's Avatar
It looks lower in person but it'll give you an idea of how it sits.
-Matt
Old 11-04-2005, 09:58 AM
The picture looks like He's gaining positive camber, that's why I asked. I just havent seen good results with adjustable upper arms. In fact I had to take some off a Camaro recently because it just wouldn't drive right. You couldn't get enough caster to not be darty and have neg. camber. Just wondering if anyone has had good luck with those uppers?
Dan
