Old 09-17-2009, 03:00 PM
61ragtop 61ragtop is offline
Default New to the site with my 61 Impala ragtop...
Hello there, I am kevin and own a 1961 ragtop Impala. Here are my specs....
ENGINE
-383 stroker 442hp/470ft lbs of torque )
-Chevy 350 bored 30 over and stroked to 383ci
-Scat crank 3.75 Stroke Cast 9000 series
-Scat 5.7 forged I beam rods with 7/16 arp cap screws
-Forged Flat top Probe Sportsman Race Series Pistons
-Comp Cams Roller Cam Duration-Intake 230deg Exhaust 236deg @ .050 / Lift Int .510 Exh .520 and 110 lobe separation
-Air Flow Research 195cc Heads 74cc chambers
-9.7:1 compression
-Headman Block Hugger Headers
-Holley Fuel Pump
-Speed Demon 750cfm Carb Vac secondaries
-Polished Air gap Intake
-Edelbrock aluminium water pump
-MSD Plug Wires
-All Bolts Are ARP
-Mini Starter
-Edelbrock double roller timing set
-Comp cams roller lifters
-Crane cams roller rockers
-Full Mandrel bent Flowmaster American Thunder exhaust With 50 series deltaflow mufflers
CHASSIS
-700r4 tranny
-3170 rpm Edge Racing 9" converter
-B+M super cooler tranny cooler
-9 inch ford rear end
-Center Section With Motive 3.89 Gears And Auburn Pro series limited slip
-Air lift easy street air ride kit
-4 wheel disc brakes
-18x7 in front and 20x8.5 rear Intro Twisted Vista Wheels
-Boxed trailing arms in rear by spirit engineering
And the dyno specs....
Intake center line 105 1/2
jets 76 front 85 rear
vac sec spring short yellow
timing 35 deg
RPM----HP---TQ---A/F--Vol Eff%
3900 - 328 - 442 - 13.3 - 97
4000 - 340 - 447 - 14.0 - 97
4100 - 356 - 456 - 14.2 - 97.3
4200 - 370 - 462 - 14.0 - 97.5
4300 - 381 - 465 - 13.9 - 97.5
4400 - 390 - 465 - 13.9 - 97.4
4500 - 397 - 463 - 13.8 - 97.4
4600 - 404 - 461 - 13.7 - 97.2
4700 - 410 - 458 - 13.8 - 97.1
4800 - 416 - 465 - 13.8 - 96.9
4900 - 422 - 452 - 13.8 - 96.7
5000 - 427 - 448 - 13.8 - 96.3
5100 - 430 - 443 - 13.8 - 95.8
5200 - 433 - 437 - 13.9 - 95.2
5300 - 435 - 431 - 13.9 - 94.9
5400 - 436 - 424 - 13.8 - 94.6
5500 - 437 - 418 - 13.9 - 94.3
5600 - 439 - 411 - 14.0 - 94.0
5700 - 440 - 406 - 13.9 - 93.5
5800 - 442 - 400 - 13.9 - 92.8
5900 - 442 - 393 - 14.0 - 92.1
6000 - 440 - 385 - 14.0 - 91.5
Old 09-17-2009, 03:40 PM
Bryce Bryce is offline
sweet car. looks really good.
Old 09-17-2009, 04:05 PM
Nice car!
Old 09-17-2009, 04:45 PM
Default !
First -- WELCOME! Nice Impala!
I have one question - and I'm no "tuner".... but those A/F numbers look pretty "lean" up in the RPM band... and leaner yet at peak torque...
Anyone??
Old 09-17-2009, 06:03 PM
70rs's Avatar
70rs 70rs is offline
Welcome aboard!! Very nice ride!
Old 09-17-2009, 06:44 PM
awr68's Avatar
awr68 awr68 is offline
Welcome!! Nice ride!!
Tony
'68 Camaro
Old 09-17-2009, 09:12 PM
Anyone??
I have been told the same on another forum and questioned my engine builder about it. I was told It had to do with how the dyno pull was performed If I recall correctly
Old 09-18-2009, 03:21 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I love the Impala 61's & 62's simple for the smaller body. I want a 62 so bad. keep her looking good.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-18-2009, 11:14 PM
T-Type T-Type is offline
sweet!!!! love the early 60's impala's.
Old 09-19-2009, 07:19 AM
Radlark's Avatar
Radlark Radlark is offline
Very clean ride my man!!
