Old 10-15-2009, 08:31 AM
1transam 1transam is offline
Default 700r4 and 9inch rear (what u joints)
I just installed a 700r4 with a 9inch rear into my 70 nova. the drive shaft u joints is where my issues are being created. the factory drive shaft is to long by about three inches. so i went to a friends yard and found a drive shaft that would fit the 700r4 and be 3 inches shorter than my factory one. the u joint on the new drive shaft is two long to fit into the 9inch housing. meaning the ridges on the inside where the u joint rest will not allow the u joint to fit. looking at my factory u joint it is much smaller than the new u joint from the new drive shaft. So the end caps on the new drive shaft along with the body of the new u joint are two big. can any one suggest a u joint with a small body and big end caps?
Old 10-15-2009, 09:00 AM
Okay here we go....
You're going to have to do a bit of investigative research here... There are MANY MANY MANY U-joints... Nobody can answer what you have if you don't know certain measurements. Nobody can guess this info.
You're going to have to have some MEASUREMENTS for what you have...
Like:
How many splines are on your 700r4 tail shaft...
This trans takes a slip yoke... The yoke itself needs to match up with whatever end you choose for your driveline. In other words - you might choose a 1350 U joint - with a 30 spline slip joint (this count needs to match the tail shaft). This slip joint can be bought in various lengths.
NEXT:
You're going to have to identify the pinion yoke on your rear end. There are various sizes here - easily identifiable by SIZE. Size being the diameter of the cap - and the width of the saddle... it could be a 1310 or a 1350 or a ??
NEXT:
With the car resting on jack stands placed under the rear axle... you only want 3/4" of an inch of the slip joint "exposed" (that would be the machined surface). Too long and it can kill your tail shaft bearings and give you a nasty vibration etc. The tail shaft inside the trans - already has a length that is "unsupported".
NOW -- there are MANY drive line sources on the internet. Start with DENNY'S DRIVESHAFTS http://www.dennysdriveshaft.com/index.html --they have TONS of info about u-joints - and the way to measure your drive shaft length etc. There's also a FAQ (Frequently Asked Questions) section detailing the difference in yoke sizes as mentioned eartlier. I've just given you a little FOOD FOR THOUGHT with my info.
Old 10-15-2009, 10:58 AM
Yeah I figured it out this am. It's a 1310 to 1330 conversion u joint i needed!
Old 10-15-2009, 10:59 AM
thanks so much for your help though!
