Old 12-06-2009, 02:33 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Originally Posted by MODO Innovations View Post
Curtis, this is one of my favorite 67's. Can you post more pics if you have them?
What are the specs on the wheels?
Sure....sorry not trying to jack your thread olskooljr.
The wheels are iForged "Astra" 18x8 front (5.00" backspace) and 18x10 rear wheels (5.50" backspace) Nitto NT55 tires, 245 wide fronts, 285 rears.
By the way...I am going to need another set of those pedals for my next car.
Curtis
Old 12-06-2009, 06:51 PM
dlouie87's Avatar
dlouie87 dlouie87 is offline
So curtis,
Your rear end is only lowered 1 1/4'' with the CAT-5?
Old 12-06-2009, 09:42 PM
Spiffav8's Avatar
Lateral-g Moderator
Originally Posted by dlouie87 View Post
So curtis,
At first it was about that. After it sat for awhile it was more like 1.5 to 1 3/4".
Here's a list and the part numbers for everything I used.
GW Tubular upper control arms w/ del-a-lum bushings
CTA-79A
Lower control arm del-a-lum bushings 1013
L-2CAT5 performance leaf springs (road racing shackles included)
GW Mono to multi leaf conversion kit 1035
DSE stock lower shock plates L/R 040302R, 040302L
Stock Replacement U-bolts 7/16" 20x6 3/4 w/nuts 040703
Curtis
Old 12-06-2009, 11:17 PM
olskooljr olskooljr is offline
Bad Ass ride!
Not sure which of our site sponsors carries GW. I bought all my parts from ATS as they where local at the time. Here's the link for the GW site.
http://www.globalwest.net/global_wes..._distridut.htm
As for your front springs. I would recommend measuring from the highest point in the front fender to the top of the tire. See how much of an opening you have and go from there. Then it all depends on what spring rate you get as to how much they will drop. What engine do you have?
Right now it has a 400SB chevy motor in it. Do you think 2" drop springs from DSE would be enough?
Old 12-06-2009, 11:24 PM
It's cool. I didnt mind seeing more pix myself. Did you need to have the rear minitubbed to get the 10 inch wheel on there?
Old 12-07-2009, 12:36 AM
dlouie87's Avatar
it's not mini tubbed.... At least I dont think so.
Old 12-24-2009, 03:59 AM
Moabdude's Avatar
Moabdude Moabdude is offline
I almost bought that car of you last year Curtis.....
I have Airride. Adjust it just the way you want it.
>68 Camaro pro touring, 400SBC, 18" Intro's, T4 13" Baer Eradispeed, Airride, Speedtech, Autometer, König seats, March, Magnaflow. Hope to finish in 2006...2007...2008…2009...2010...2011...Yes, 2012 and its finished (well, will it ever be finished )
>69 Nova project, LS1/4L60e, Corvette C5 calipers+rotors, AFX spindles, 69 Camaro body mods, Just got it painted.
Old 12-24-2009, 08:43 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Gorgeous cars guys!!
Very nice.
Old 12-28-2009, 03:37 PM
Hotchkis Hotchkis is offline
senior member
Default Drop Springs for Camaros
If you want a dramatic difference, I second the suggestion for 3" drop kits. Hotchkis now offers a full 3" drop TVS with springs, leaf springs and sway bars for the perfect stance and improved handling.
All the lowering springs are also available individually. For a closer to stock ride height, we offer a 2" drop kit for both front and rear.
