View Poll Results: What motor would you do?
LSx 165 81.68%
Supercharged SBC 400 w/ EFI 37 18.32%
Voters: 202. You may not vote on this poll
Old 12-24-2009, 11:42 AM
scherp69's Avatar
scherp69 scherp69 is offline
Originally Posted by anthony 69 View Post
how much hp do's a stock L92 make. what would it take make 570-600hp same with the LS7. thanks
Not sure if you've made up your mind or not, but to give you an idea of what my L92 that I'm putting into my 68 Acadian (Nova) will cost. It should be close to 560 - 570 hp when I'm done, which is what you were asking. I'm keeping the VVT so it might cost me a bit more. I'm using the Mast Motorsports controller and cam set up. http://www.mastmotorsports.com/page....Packages&id=70 It runs about $2500. It includes their SS cam, valve springs and their controller. For an extra $299 you can get the software and usb cable to program the controller your self. For another $500, you can get a controller that is already set up to add a turbo down the road. I'm going to add the Speed Tech/Stainless Works long tube headers (about $1400 but are the polished ones, $950 not polished, I'm using those as they are designed for the Speed Tech Subframe). I also have the new FAST 102mm intake ($800) and will be adding a 102mm Nick Williams DBW throttle body ($500). You can use the stock truck intake, which apparently flows better than the stock car intake. This should put me around the numbers that I hope to get...which seem to be around the same that you want.
I know Frank was doing a L92 deal where he replaced the VVT and put in a new cam and springs and a stock LS3 intake. They were making 525hp so as you can see...doesn't take much.
I know I voted for LSX but at the end of the day....you need to choose the way you want to go. I decided to go LS because the last few sbc's I did...I was constantly playing with the carbs, timing, etc. I'm sure part of it was cause everytime I adjusted something, I made matters worse. I really like the idea of having big power, good fuel mileage, reliability, etc. But I decided that's how I wanted to go. If you like the old school looks with the charger...than do it. It's your car...you need to be happy with it. Good luck with the decision if you haven't already made up your mind.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 04-11-2012, 06:11 PM
INJECTED69's Avatar
INJECTED69 INJECTED69 is offline
Lsx !
Injected69
Old 04-14-2012, 01:08 PM
G-Body's Avatar
G-Body G-Body is offline
Not even close the 400 all day long and twice on sunday!
Old 04-14-2012, 11:37 PM
FETorino's Avatar
FETorino FETorino is offline
so far we have 135 views and only 16 - 17 votes. come on vote, your vote could help me deside sell my sbc parts and buy an LS motor over magnacharger. i was thinking of doing the 400 sbc. id also like to see pics of your engine bays .thanks anthony
I tried to vote for a 427 Ford side oiler but the option wasn't on the poll...... I'm three years late anyway
Rob in SoCal
Old 04-19-2012, 11:15 PM
Rod P's Avatar
Rod P Rod P is offline
I voted LS but you cant really compare the SBC to the LS, sure there both chevy V8's, but they do everything completely different, power delivery, torque curves, sound, Idle characteristics, weight, length and so on
my car (Plain Jane) SBC powered 2011
my car (Plain Jane) LS powered 2012
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 04-20-2012, 08:03 AM
clill's Avatar
clill clill is offline
Now that.....is a radiator hose.
Old 04-24-2012, 05:08 AM
Gatekeeper's Avatar
Gatekeeper Gatekeeper is offline
I voted LSX.
Gatekeeper
Old 04-26-2012, 12:37 PM
Den69RS96's Avatar
Den69RS96 Den69RS96 is offline
I know i'm in the minority here on this site, but I still love the gen 1 smallblock. LS motors def have the advantage in the hp department, but to me the gen 1 engines look better and sound better. I personally love the sound of a high compression, cammed, gen 1 smallblock.
69 Camaro, 350 .060 over, Trickflow heads, 4 spd, Flowmaster, Hotchkis suspension, Moser 12 bolt, Baer Serious Street brakes
Old 05-01-2012, 07:30 AM
LSfan70s LSfan70s is offline
LSX
Old 06-16-2012, 09:58 AM
anthony 69 anthony 69 is offline
Just an update I’m putting the 400 sbc in an 85 camaro. And I am going to get a 427 short block from dart and put the supercharger on it. I must say things have been going a lot slower than I hoped. I’ve got big ideas [dreams] and empty pockets but it’s getting there
''Courage is being scared to death
- but saddling up anyway''.....John Wayne
