Old 12-29-2009, 06:13 PM
Originally Posted by tony byram View Post
Woah! Youre gonna stuff some serious rubber in those fenders! Now thats going to look killer that little Vega with huge rollers on the rear.
the rear wheelwell is 15" wide with the minitub. I need to see what will fit up front after doing some sort of custom subframe, and then balance the rear tire size with that. In other words, I don't want 335's out back if I can only fit a 235 up front.......................
Old 12-29-2009, 07:45 PM
DaleLee DaleLee is offline
Thanks for the compliment Jody! As far as trying to fit a wide tire up front, I would rule out the s10 spindle swap entirely. The track width was actually a little wider than stock Vega when everything was said and done with Wilwood brakes. The front rim on that car is only 4" with a centered backspace, and to get the car as low as it is in the picture, the tires are setting with more negative camber than I would like on the street. I would go custom entirely. Good luck with your project! I can't wait to see more!
Dale Lee
Dale's Speed
www.dalesspeed.com
Old 12-31-2009, 01:49 PM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
Originally Posted by awr68 View Post
I've seen it and it is a cool car!
me too it is a cool car
^^^^^^^ So nanner nanner to those of you that think I just make this S*** up!
Greg arent you always making up stories
Luke Mau
L & H Kustoms
Old 12-31-2009, 01:56 PM
Yeah Luke --- I'm a regular fibber with my pants on fire...
Old 12-31-2009, 03:31 PM
lhkustoms's Avatar
Greg your too funny and you forgot your trademark
eeeeeeeeeeeeeeaaaaaaaaaaahhhhhhhhhhhh
Luke Mau
L & H Kustoms
Old 12-31-2009, 05:22 PM
avewhtboy's Avatar
avewhtboy avewhtboy is offline
Glad to see someone doing this. My first car was a vega, pos motor like others said but fun car otherwise.
I have been thinking about building one as well. Corner carver cosworth vega with a turbo charged cosworth engine 400-500hp.
Looking forward to seeing how much front tire you can stuff in there.
