Old 01-25-2010, 09:40 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default BRP Hot Rods LS Conversion
Anybody running the BRP Hot Rods LS conversion kit on a Camaro? In looking at their website, it appears their kit makes the motor sit higher and closer to the radiator. I was curious if anyone had photos of their engine compartment with this kit.
Chris
Old 01-25-2010, 02:03 PM
There's a number of people using them on ls1tech.com. They also have a line of headers out that are made by hedman. I've never used them personally but I'm not a fan of their design. It just looks weak using those control arm bushing type things instead of a traditional motor mount. Maybe it is perfectly fine but it just looks weird to me.
Old 01-25-2010, 04:54 PM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
I ran it. Im about to remove it and go with either a factory setup or an aftermarket subframe. The BRP kit makes the turning radius about the same as my crew cab longbed truck.
Kyle
Old 01-25-2010, 08:59 PM
1970camaroRS 1970camaroRS is offline
How does a motor mount kit affect turning radius?
Old 01-25-2010, 09:11 PM
never mind. i guess they changed their setup. i just checked their website. I had their original kit from back in 2003 ish. It required a new rack and pinion and it changed the radius.
Kyle
