Originally Posted by Bow Tie 67
Precise fuel controll when tuned correctly.
I don't want to jack Steves thread -- but this whole "compression" and fuel management thing brings up some thoughts about the LSx motors....
I'm a pyro.... and as such understand a bit about "compressing" explosive chemicals...
I think that we all know "more" compression is a problem and that for the problems it creates - the power increase is actually minimal... Which got me thinking about why the factory LS motors use what we used to think was an unworkable compression ratio on todays pump gas...
But they seem to make great power - AND use LESS fuel to do it - and they're using leaner mixtures (except at WOT). So when you compress LESS fuel/air - you get a little more "bang" for your buck... So.... I'm thinking they're on to something here.... (and they employ built in safeguards). You take less fuel - atomize it really well - get more flow into the cylinder with better heads - then you compress the hell out of it... and you're making some power while sipping gas. The gas sipping is partly due to the leaner A/F they can run (coming back to the EFI issue)... The control with knock sensors... AND let's not forget the 6 speeds and tall gears... (low rpms per mile). BUT you have power when you want it because of great heads - and high compression ratios... then toss in some 12:5 AF at WOT....
Just thinking out loud here....
