Old 04-05-2010, 05:06 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Default Stainless Works mufflers, Hydra-boost, Wilwood MC
Need to get rid of a few things. everything is new never used.
Stainless works Turbo Mufflers for a 67-69 camaro $115 each Free shipping Regular Price $167
From their website,
3" ID OFFSET INLET/ 3" OD CENTER OUTLET, 5x9x14" SHELL, - OUR S-TUBE TURBO MUFFLERS ARE CONSTRUCTED ENTIRELY OF HIGH QUALITY, TIG WELDED 304 STAINLESS STEEL WITH STAINLESS STEEL WOOL PACKING AND COME WITH A LIMITED LIFETIME WARRANTY. THESE MUFFLERS WILL NEVER "BURN IN", "BLOW OUT", OR CHANGE THEIR TONE EVER. THE STRAIGHT THROUGH TURBO DESIGN OF THIS MUFFLER OFFERS MAXIMUM FLOW WITH A DEEP MUSCLE CAR RUMBLE AT IDLE AND CRUISING SPEEDS WITH NO DRONE, AND A VERY AGGRESSIVE TONE WHEN YOU JUMP ON THE THROTTLE. THESE MUFFLERS COULD BE USED FOR A DAILY DRIVER BUT MAY BE CONSIDERED TOO AGGRESSIVE BY SOME. FOR A MORE CIVILIZED DAILY DRIVER MUFFLER WE ALSO OFFER OUR PERFORMANCE 3 CHAMBERED TURBO MUFFLERS.
HYDRATECH 67-69 CAMARO/NOVA 'F' Body Hydraulic Brake Assist Unit - Model # 3023 SOLD
from there website
CNC Machined T6 billet aluminum direct fit firewall mounting plate design
o This model fits the earlier GM "long rod / deep" master cylinder design
o All engines with PS pump on driver's side - compatible with rack and pinion conversions
o For use with disc/drum or disc/disc brakes (not for use with 4 wheel drum brakes)
o Features an adjustable brake pedal rod to allow for a range of brake pedal height adjustment
o Models with PS lineset include overlength hoses with re-usable / re-buildable hose ends
o 7 1/4 " installed length from firewall to MC mounting flange - no firewall modifications required
Wilwood 1.125 Master Cylinder $150 free shipping Regular Price: $199
from there website
Wilwood’s tandem chamber master cylinders are fully machined from a High-pressure die casting of a premium alloy, it incorporates slotted mounting flange to accommodate mount centers between 3.22" to 3.40" and also features side-hole mounts on 6.40" centers. Master cylinder is has full separation between the front and rear chambers . Dual outlets allow for right or left hand plumbing based on mount location. Offers a total piston stroke of 1.10” and a 2:1 volume ratio between the primary and secondary chambers. Available in 7/8”, 1" or 1-1/8" bore sizes. Available also in a media burnished version and a black E-coat finished units
Fesler 3D RS Tail lights. Polished $420 free shipping Regular Price $480
Brand New never installed on car.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 04-12-2010, 05:03 PM
96z28ss's Avatar
Sold the Hydraboost
Old 04-13-2010, 09:34 AM
96z28ss's Avatar
Lowered the price.
Old 05-11-2010, 11:22 AM
96z28ss's Avatar
Added the fesler taillights.
Old 05-17-2010, 02:20 PM
holmespine holmespine is offline
Default master cylinder
will the master cylinder fit a 68 camaro? which hydratech will fit the master cylinder? the one you sold, the #3023?
thanks,
paul
