Old 12-24-2005, 12:24 AM
race-rodz race-rodz is offline
Default custom spindles?
anybody got any expierince with custom fabbed speedway style spindles? i have been kickin the idea around, they are cheap, built to my specs, and with a forged alum hub/rotor carrier...... i can use whatever size brakes i want.
the other option is a set of one off milled out alum uprights with C5 bearing carriers, obviously this is waaaaaaaaay more money, and im really not sure if its a better way to go.
any insite would be great...thanks
Old 12-24-2005, 09:47 AM
sinned's Avatar
sinned sinned is offline
I have a set designed and ready to be ordered. My hesitation is replacement should the unexpected happen. It would suck to have a month to get a replacement spindle.
Dennis
Old 01-16-2006, 09:46 PM
KAA's Avatar
KAA KAA is offline
Now this sounds very interesting. I'm curious to know just how "custom" you can get. Are the steering arms part of the spindle or bolt on? What about disc brake caliper mounting? Can they be machined to accept any type of balljoint, hub, etc? One thing I'd like to do is eliminate the 1" wheel adapters I'm using. It looks like I could have a custom made spindle with a 1" additional offset. Or is that a bad idea?
Keith
'70 El Camino SS L78 396 - It's back!
Lateral-g Feature
Chevy High Performance Feature
'09 Viper SRT-10X
Car Craft 2009 RSE Winner
Car Craft Feature
NARRA Road America TTU Record Holder
Old 01-16-2006, 09:57 PM
sinned's Avatar
I can dictate the height, pin drop, pin type, steering arm height and length, amount of hub set back (there you go Keith), and KPI. It helps to know how to read an analysis and obviously have access to one. You have to provide them with every single spec down to the tenth of an inch.
Dennis
Old 01-16-2006, 10:18 PM
KAA's Avatar
KAA KAA is offline
Can I just send them my B-body spindle and have them make me a new spindle that fixes all the problems??
Keith
Lateral-g Feature
'09 Viper SRT-10X
Car Craft Feature
Old 01-16-2006, 10:21 PM
sinned's Avatar
HAHAHAHA...no.
Dennis
Old 01-16-2006, 11:04 PM
KAA's Avatar
KAA KAA is offline
So where can I find the dimensions of the B-body spindle? Seems like that would be a good place to start. Then make the changes I want instead of starting from scratch. Pin location and steering arm would be the only things I'd change.
Keith
Lateral-g Feature
'09 Viper SRT-10X
Car Craft Feature
Old 01-17-2006, 02:58 AM
ProTouring442's Avatar
As I understand it, the ATS spindles address many, if not most of the B-Body spindle issues. They also will be making a set for those of us who already have the B-Body mod done so we won't have to change ball joints.
Shiny Side Up!
Bill
'72 442 "Inamorata"
Old 01-17-2006, 06:13 AM
sinned's Avatar
Go grab another one at the wrecker and start making some measurements. You may also want to change KPI.
The ATS spindle is a better alternative to the "B" spindle but Speedway spindles are much better. Remember that the AFX was not designed for the "A" body, it was designed for the "F" body which has a different set of needs. It just so happens to work pretty good on the "A" body as well, but not perfect by any means.
Dennis
Old 01-17-2006, 01:44 PM
KAA's Avatar
KAA KAA is offline
Reduce the angle?
Keith
Lateral-g Feature
'09 Viper SRT-10X
Car Craft Feature
