67-69 F Body, 1 5/8", 3 Bolt Collector Flange - Mill Finish
 http://www.xplosiveperformance.com/6...sh_p_1885.html
http://www.xplosiveperformance.com/Exhaust_c_6540.html
67-69 Small Block Chevy F-Body headers. 1 3/4", .065 wall thickness, CNC mandrel bent primary tubes. CNC laser cut flanges, 3" 3 bolt collector flange. These headers fit perfectly without dimpling the primary tubes around the steering box. Long tube design provides awesome low end torque and street performance. Sold less gaskets and fasteners. Mill finish. Will work with straight or angle plug heads. Will not work with factory A/C. These are the best fitting header and the only headers designed specifically for 67-69 Camaros. Works great with lowered cars.
Exhaust System, 67-69 Camaro 3" SS with X-Pipe
CNC mandrel bent huge 3" diameter Everlast 304 stainless. Designed to fit Stainless Works headers. X crossover with dual 304 stainless turbo mufflers. Exits behind rear tire. Hangers not included. Hot rod system for 67-69 small block or big block Camaro.
http://www.xplosiveperformance.com/E...SW_p_1926.html
http://www.xplosiveperformance.com/E...pe_p_1892.html
http://www.xplosiveperformance.com/C...69_c_6537.html
CALL OR PM FOR ADDITIONAL SAVINGS
GET FREE SHIPPING ON THE ABOVE SYSTEMS IN THE LOWER US UNTIL THE END OF THE MONTH OF JULY
