Old 07-14-2010, 07:06 PM
J-440's Avatar
J-440 J-440 is offline
Default Duel pass radiator
I think this might have been discussed before, but what is the difference between your standard aluminum crossflow radiator vs. a duel pass radiator. Besides the obvious difference that both inlet/outlets are on the passnger side, is there a performance or cooling gain? Thanks.
68 Charger, 440SC, EFI, 6-speed
Old 07-14-2010, 09:45 PM
Go read this --- then you'll be able to duel your way into a conversation about dual pass radiators...
http://www.carcraft.com/howto/ccrp_0...em/basics.html
Old 07-15-2010, 06:02 AM
ccracin's Avatar
ccracin ccracin is offline
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 07-15-2010, 06:37 AM
We sell and install dual pass on every application we can. We see as much a 15 to 20 degree additional cooling on water heaters. We see higher temp drops from the inlet to the outlet on dual pass. On or cross flows we will see a right around a 30 degree drop and on a double pass we can push near 40 degree temp drops
Added
Fan, Fans, Fans. Fans are your friends. Try to find a way to get at least a pair of High Performance 13s on your radiator. And make sure they are on a professional built shroud. Most radiators systems show their inadequacy at the worst time when you need them the most. When your sitting still, in high heat, A/C on cause no air is moving through the cabin. Nothing sucks worse then having to shut off the A/C and roll down the windows cause the car is warming up. Then once you roll down the window the old lady starts warming up.........................then you hear Michael Buffer, Let's get ready to RUMBLE!!
Frank Serafine
Old 07-15-2010, 06:39 AM
Good info Frank!
Old 07-15-2010, 12:48 PM
J-440's Avatar
Thanks for the Car Craft ad Greg. Love the Prodigy website. Think I'll be doing some shopping there in the future. Once again ya'll have been a big help.
Old 07-15-2010, 06:13 PM
pokey64's Avatar
pokey64 pokey64 is offline
We picked up a dual pass Prodigy Cool Package for our BBC and its a real nice piece
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 07-22-2010, 06:11 PM
J-440's Avatar
One more question. Clearance is kind of tight in my engine compartment and I might have to use a set of "pusher" fans. I have heard from different sources that pushers don't cool as well as pullers. Well why do they sell the dang things? If I'm sitting in traffic with no airflow, my fans, regardless of location, are going to be cooling the radiator. Lemme know cause I'm getting ready to make a purchase.
Old 07-22-2010, 06:33 PM
I have never seen a set of pusher fans that were worth anything. How much room do you have between core support and accesories?
Frank Serafine
