Old 07-23-2010, 08:33 PM
aany001's Avatar
aany001 aany001 is offline
Default Fuel tank question
I was wondering if I can use my carburated stainless tank to feed an LS1 in my 69 camaro.I will be running a carb for now but when I convert to fuel injection will I have to replace my tank????
Old 07-24-2010, 04:15 AM
deuce_454's Avatar
you will need to have it modified with internal baffles and preforably an in-tank fuel pump
Jake: Hit it.
Old 07-24-2010, 07:57 PM
aany001's Avatar
even if I will only use the car as a street car I still need to baffle the tank?? It just wont work with a standard tank and external pump??
Old 07-25-2010, 03:18 AM
deuce_454's Avatar
it will work great when the tank is full... (external fuel pumps are a bit more noisy.. but with a nice exhause, who cares) but when you are down to the last 3 gallons it will cut out in long corners.. fuel will slosh away from the pickup and you will loose fuel pressure and the engine will cut out immediately.. then when you are outr of the corner it will spring back to life...
so yes it will work.. but not well when not full
Jake: Hit it.
Old 07-25-2010, 01:05 PM
aany001's Avatar
So what your saying is that for street cruising and you dont let the fuel go below 1/4 tank I should be good to go?? Also do I have to install a return line for a 99 LS1?
thanks
Old 07-27-2010, 02:04 PM
deuce_454's Avatar
return depends if you are running a referenced fuel pressure regulator.. if not then you could run a single feed and keep the pump and reg in the tank.. and im by no means saying its a good solution... but if you keep the tank atleast half full... or more it shouldny be a big issue...
but i dont get why you are so set on not doing it right.... its always cheaper to do it right the first time.. you are going to end up changing it anyway when it bugs you enough ....
Jake: Hit it.
Old 07-27-2010, 03:42 PM
aany001's Avatar
reason why is that I already bought a carb style stainless tank... just trying to use what I already have.
Old 07-27-2010, 09:42 PM
I started out with a carb tank -- it's stainless steel from Rock Valley... it's already baffled. What you really will need is a SUMP... and of course a return line for the the LS style motors (almost all EFI engines use a return system). This is all very simple and can be added when ready.
I use an external pump and can't hear it with my motor running. Tis a hot rod not a mercedes benz! EEEEEEEEHHHHHHHHHAAAAAAAAAAA
Old 07-28-2010, 07:28 AM
aany001's Avatar
Does anyone know if the carb tanks have any baffles at all? I am willing to sump my stainless tank.
Old 07-28-2010, 08:11 AM
Depends......
As in - what kind of tank it is - and who built it. Without that info nobody could answer that kind of a question. Stock factory tanks had no baffles... including the SS replacement versions. Rock Valley and Ricks Tanks etc - would be baffled. Baffles would take care of fuel SLOSH... they DO NOT take care of cavitation at the intake caused by a lack of coverage.
EFI draws large amounts of fuel at all times... Think "toilet bowl flush". Fuel boils under suction... so the supply lines to the pump need to be sized for the application... and they need a nice clean flooded "head" for supply. Think -10 AN for the supply side MINIMUM. A SUMP helps to keep the supply flooded. It needs to be at the rear and bottom of the tank (unless you're internally sumped and baffled). You need adequate fuel going UP HILL and when you're accelerating hard. You don't need much coasting downhill or just cruising on a level street. EFI will not run on air bubbles and fumes... there's no pressure made in that instance. You can use your existing supply line as the return. Again depending on the proper size for the application. If you're planning a 900 HP blown EFI motor -- the factory line would be totally inadequate.
