Old 09-12-2010, 07:37 PM
BritishGreen68 BritishGreen68 is offline
Default ISISAccuairAlarm all in one?
Im running air ride, a nice alarm and a lot of extra electrical stuff on my Camaro (as a lot of us are) Is there a company that integrates all the stuff we need in one system? I don't want one remote for the alarm, another remote the air ride and all these $1000 kits. I would like to have one remote with air ride controls (love the Accuair remote), alarm arm/disarm maybe windows up/down, and an electrical system that is simplified all in one swoop... thoughts?
pic for clicks why not...
Chris
Under construction-British Green 68 Camaro-
Old 09-12-2010, 08:35 PM
sniper sniper is offline
What type of alarm do you have? What ever it is, as long as you have aux channels, you can run whatever you want from the remote. And if you want, you ran use a channel expander to get 6 additional aux channels.
You can run a 530t for two windows up and down. Get two if you want to control the rear windows as well.
You can also use an aux channel of your remote to operate the accuair. We do it on all installs with a alarm/remote setup.
Now if DEI would just get the aux cahnnels to work with the smartphones. That would be smokin. I like to set up a relay board of sorts. That way you can neatly wire in access to +12, ign and ground very easily. You can also you 9 wire to run all the triggers fromt he alarm to the relay. Makes things real tidy and simple.
That's a good looking car you have there.
Old 09-12-2010, 08:56 PM
Ok thanks for the info, the nova was a friends but it has since been sold.. ya all I really needed was an all down and maybe an "up to ride height" control and then alarm functions on the remote. I guess controlling the air valves from another source such as an alarm aux would be pretty simple. I am pretty familiar with alarm installs and electronics I just keep seeing all these systems come out but they never have every feature... you always have to try and make several things function together and its expensive!
Chris
Old 09-13-2010, 12:30 AM
wellis77's Avatar
wellis77 wellis77 is offline
ISIS will definitely and easily pull off what you want, and more... Check them out, and give Jay Harris a call.
Old 09-13-2010, 12:48 AM
Musclerodz's Avatar
unless something has changed ISIS can't support the air ride functions. You may be able to go up or down, but will not control preset ride heights. I have talked about that with jay in the past. Everything else should be doable.
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-13-2010, 07:14 PM
Supporting Vendor
For those out there reading this that have the same problem:
(I am in charge of control systems at Ridetech, formerly Air Ride Technologies; just so you all know I'm providing information, not trying to sell anything)
I had this question a lot with the e2 system, so with the e3 we created a remote "Node". The node is a small box that plugs in-between the ECU and the display that accepts the antenna. It also has 3 ground inputs that can be connected to any momentary button the installer chooses (so you can hide everything if you want: I used the presets on an old AM/8-track unit to control the air ride presets on one project.) But if you have an alarm system you can also use the aux. outputs of the alarm to trigger the presets.
One remote for everything.
Skunk Werks
Ridetech
www.ridetech.com
Old 09-14-2010, 01:06 AM
wellis77's Avatar
I knew you can go up and down, surprised can not control preset ride heights though. I wonder if it's possible to set it up between the air controls and ISIS that when the car is remote started the suspension inflates to ride height? I haven't even started with wiring, just thinking and imagining for now, so maybe something will change when I get to that point.
Old 09-14-2010, 06:29 AM
Supporting Vendor
Remote Starting:
Most control systems have a "level on start" feature. So if you remote start the vehicle it will automatically raise to ride height.
Skunk Werks
Ridetech
www.ridetech.com
