Old 10-16-2010, 03:04 AM
bulldog19 bulldog19 is offline
Default Transmission Noise
I have a TK0600 that when shutting the car off, in neutral makes a sound as if there is loose spring or something in the transmission. IF i press the clutch in the sound goes away. Is this something in the trans? clutch? My 1st thing i was going to check was the clutch linkage and return springs on the the pedals but did not know if any one had experience this with the tremec.
Bulldog
John
68 Camaro RS Convertible Dual Quad 406 TKO600 Hotchkis TVSS SOLD
Old 10-16-2010, 05:00 AM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
Possible broken spring on the clutch disk, or bad throwout bearing
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 10-16-2010, 11:13 AM
greycamaro greycamaro is offline
throw out bearing will make a noise when the clutch pedal is mashed( more of a metal on metal sound). more than likely you have a bad pressure plate
Old 10-18-2010, 02:58 AM
Thanks for the suggestions. I'm going to pull it apart this weekend and see what's going on.
John
Old 10-18-2010, 07:46 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Yeah, or your clutch isn't torqued down correctly. That rattling sound is more than likely the pressure plate. That's why when you mash the pedal, hence taking the PRESSURE off of the plate it stops.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 10-18-2010, 10:22 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
C5 Z06 corvettes and the 04-05 CTS-V's do the same thing. unless it just started doing it out of the blue and not from day 1 its just the nature of the beast
