Old 12-20-2010, 02:48 AM
ky69 ky69 is offline
Where did you get the piece to mount the hydroboost to the firewall? The aluminum looking piece? Thanks!!
Old 12-26-2010, 12:05 PM
Nick's Avatar
Nick Nick is offline
Originally Posted by Bobs 67Camaro View Post
Looks Great!
How do you like the brakes? Do the Brembos share the same mouting holes as 5/C6 Calipers?
Brakes are great!! Sure stops the car on a dime. I am not sure if the brembo calipers share the same mounting holes as C5/C6 calipers. I made custom caliper brackets to mount the brembo to the stock spindle and drum brake hub.
Sorry if I could not confirm, if you need measurements for the brembo mounting holes, I could probably dig up my templates.
Cheers
Old 12-26-2010, 12:12 PM
Nick's Avatar
Custom made with 1" Al flat stock. I modified the original Astro mounting plate to match the mounting of the Camaro firewall and then made that Al plate with a hole in the center big enough for the hydro boost mounting nut. Let me know if you need more details.
Cheers
