Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 01-25-2011, 05:24 PM
DOOM's Avatar
DOOM DOOM is offline
Default Wanted mock up tire !!!
I'm looking for a 345 or a 355 -30-19 tire anyone have one laying around . I need one for mock up . I'll take anything I just need one.. PM me if you have one let me know how much...
Mario
USCOLLISION
Old 01-26-2011, 09:11 AM
96z28ss's Avatar
96z28ss 96z28ss is offline
too bad I have 335/30/18 michelin mock up tires.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 01-26-2011, 10:04 AM
DOOM's Avatar
Story of my life Bob..
Mario
USCOLLISION
Old 01-27-2011, 05:39 AM
Payton King's Avatar
Default I do not have one either
I just bought a set of 335/30/19 Nitto NT05's for my car. They are on a 19x12.5 rim and fit perfect. Saying that only because the tire selection is real limited for sticky rubber in that size. PS2, NT05 or Hoosier slicks. If you bump up to 345/30/19 I believe the best tire is the PS2. Nitto makes an tire called an INVO which is a good street tire. Not sure what you are looking for in a tire or what you plan on doing with your car.
I like the look of an 18/19 on a 69 camaro and went with those sizes knowing I was going to be tire limited. I will tell you the 335/19 does look bad ass mocked up on my car.
Old 01-27-2011, 06:00 AM
DOOM's Avatar
Paton... Cris (JCG) Is going to send me his back space tool and I just need a mockup tire to mount on it. So thats why I don't care what brand of tire it is as long as its in this size range. Hell I don't care if its bald, has a hole in it,flat spoted just need one.
Mario
USCOLLISION
Old 01-27-2011, 11:10 AM
Default Do you have a rear already
that you are trying to figure out the backspacing for a rim that will work under your 69?
I have some data from my 69 that may be helpful. What are you trying to figure out?
Old 01-28-2011, 06:13 AM
DOOM's Avatar
I have the rear end ready to bolt in. I'm just about to finish up my outter wheel houses then I can start measuring. Yes.. back space/offset. Just don't want to make any mistakes.. I was going to use Kjells measurements from MCC its the same exact rear end set up as mine he also has Mikes frame rails and Mikes extra deep tubs witch is another 2.75 added to the DSE tubs. So we have a ton of extra room. Then I found out from Zak at BOZE FORGE that my hoop will be different because of the ZR-1 calipers so he wants me to make sure I have everything measured correctly. Trust me I would have my wheels already if I used Kjells measurements but I want my wheel to be as close to the quarter lip as possible. Kjells is just a little to far in for me. So thats one more reason. Hope this makes sense...
Mario
USCOLLISION
Old 01-28-2011, 07:47 AM
Default That car is in Dan Holohan's shop sitting next to mine
Black 69 with DSE sub, HRE's, LS7, guy from europe? Call me at 704-564-8577. I can get you any measurement and picture you want.
Not sure why the brakes would make a difference as he is running the huge Baer 6s. They are as large or larger than the ZR-1 stuff.
Old 01-29-2011, 05:34 AM
DOOM's Avatar
I will give you a call!
Mario
USCOLLISION
Old 01-29-2011, 01:45 PM
pro-touring.no's Avatar
pro-touring.no pro-touring.no is offline
Default Im here
Whats up guys?? I had the same wishes on my car.. to get the tire as long out as possible.. have you done somthing to the outer wheel well..you need to do so if you will get it to sit rigth..
greetings from cold Norway
My Shop
PTS
