Old 03-20-2011, 07:10 AM
torino420's Avatar
torino420 torino420 is offline
Try rotating the drive shaft 180 degrees? I had a similar vibration once and this did the trick for me.
69 Torino GT Formal Roof
420" Windsor TKO600
Old 03-20-2011, 11:54 PM
David Pozzi's Avatar
What is the angle between front yoke & driveshaft?
Without cutting the floor to raise the tailshaft, I've seen too much angle.
http://www.PozziRacing.com
Old 04-03-2011, 07:41 PM
sweatnblood sweatnblood is offline
Ok just dropped her off at the dyno shop to get a CV joint put in...hope this works...will let you guys know when i get her back...wonder how much HP loss moving from aluminum to steel shaft...
