Old 04-24-2011, 08:54 PM
MoparCar MoparCar is offline
Thanks-nice looking piece for the hydraboost.
Wes
Old 04-25-2011, 05:19 PM
johns cuda shop's Avatar
johns cuda shop johns cuda shop is offline
Thanks, they are made from 1" thick 6061 T-6 aluminum . They fit mopar 68-72 b-bodies and 70-74 e-bodies. Just add your hydroboost unit and go
Old 04-28-2011, 10:59 AM
I Added Braces out of 2" X 2" tubing for the transmission crossmember, Boxed the ends of the crosmember with 1/8 thick and Im gonna connect it together with a piece of 1/4 X 4" I bent to go around the transmission
Old 04-29-2011, 12:00 AM
mrgm mrgm is offline
nice..,..;...
Old 05-01-2011, 06:59 PM
I got the engine on the stand this weekend, I should get a rear sump oil pan this week . I took these pics over the weekend
Old 05-08-2011, 01:18 PM
The new bellhousing from Keisler uses a automatic bell, I think its from a 4L80 but I am not sure. As you can see it uses a 1/2 thick aluminum adapter plate to convert it. Extra throw out bearings spacers came with the bell. The quicktime bell will not clear the T56 Magnums fron oil pump bosses. I like the fact that its 13 lbs lighter and matches the aluminum block
Old 05-08-2011, 06:05 PM
scottysimp7's Avatar
scottysimp7 scottysimp7 is offline
Cuda's are one of my favorite body's out there. Cant wait to see more
68 Camaro
DSE sub
Quadralink Rear
Ford 9inch
Baer Brakes
Skip White Racing 421sbc
Tremec TKO600
Old 05-09-2011, 07:28 AM
that is a nice piece.
Old 05-18-2011, 04:07 PM
Before the motor goes in , I wanted to do most of the sheet metal work and repairs to the engine compartment . Looks like the upper cowl (cudas are notorious for rusting there) and LH inner fender needs replacement. I spent the day drilling spotwelds and carfully removing sheet metal with a hand chisel. This is what I got done today.
Old 05-19-2011, 12:15 PM
wedged wedged is offline
in case you didn't know, a stock truck hemi oil pan and pick up clear the alterkation k frame.
