Old 05-09-2011, 10:27 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Originally Posted by DJW32 View Post
Didn't you just add a GV unit to your Camaro?
Yes---but now, since both motor and trans are going to come out--and the new LS3 is going to go in, I have a chance to maybe make a change now--cause after it goes back in, I'm not going to swap out after that. The Gear Vendor and the Turbo 400 will go up for sale as a unit here in the next couple of weeks---if no takers, then back into the car it goes with the LS setup.
DFRESH
Old 05-09-2011, 10:30 PM
DFRESH's Avatar
Originally Posted by Mkelcy View Post
Good summary. If Doug's using full height body bushings, the only trans tunnel modification should be relocating the shifter access hole, if he has one in the car now.
So Mike, of course mine has the half inch high body mounts in it---part of why it sits as low as it does. I seem to remember Todd having some drama on Payback regarding this very issue--have you had experience in this area also?
Doug
Old 05-09-2011, 10:34 PM
DFRESH's Avatar
So, where do I go for the T56 Magnum Trans? Suggestions?
Old 05-09-2011, 10:39 PM
1/2 height bushings and T56=Cut off wheel
Old 05-09-2011, 10:43 PM
DFRESH's Avatar
Nice---the whole tunnel or only half---
Me and my goal of one mod at a time---lol
I'm going to send the whole thing to you---you can finally make money working on a 69 Camaro---
Old 05-09-2011, 11:02 PM
gearheadgarage's Avatar
gearheadgarage gearheadgarage is offline
Just put a pumped LS6 injected motor in a '69 Camaro- customer decided not to run his brand new T56 Magnum because he has too much custom work done & doesn't want to re-hash. If he has it, and accessories, you might get a hell of a deal.....plus he is in So-Cal.
Let me know if you're interested, I'll try to hook you up!
Old 05-09-2011, 11:26 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Doug
Only from looking at the tight fit of a T56 in my '68 with full height body bushings.
Well we all have to pay at or near market price, but you will find one at the Lake Forest swap meet soon for probably about $350.
Old 05-09-2011, 11:27 PM
DFRESH's Avatar
LOL Dave---so true---LOL
Old 05-09-2011, 11:28 PM
DFRESH's Avatar
Yep---set it up brother--and thank you!
Doug
