Old 05-08-2011, 09:10 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
I had a few hours today to work on the car, so I finished up my top half of the driveshaft safety hoop, and worked on my gas tank access door a bit.
I still need to get some hinges and a latch/ fastener for keeping it closed.
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 05-09-2011, 07:41 AM
The top part of the driveshaft loop came our great. The access panel will save a lot of work if you need to get to the sending unit later on. Nice.
Old 05-09-2011, 09:08 AM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
Progress is awsome with a lot of nice touches. Keep up the good work.
Old 05-09-2011, 10:06 AM
syborg tt's Avatar
Great progress on the car. I am going to borrow you floor trimming for the exhaust.
marty-mj
Old 05-15-2011, 07:52 PM
Tuske427's Avatar
Thank you, everyone! It means a lot to receive the kind words.
I spent some time yesterday finishing up the fuel tank access panel. I purchased a hinge from Lowes and modified it. I welded the hinge to the door but not to the trunk. I used some buttonhead allen screws and welded some nuts on the underside and used one larger one for securing it shut. I plan on using some type of weatherstripping to help seal it and prevent any vibrations or exhaust leaks. I also trimmed the allen bolts to length. they are untrimmed in the pics.
The metalwork is for the most part there, but it will need some bondo/ prep work to get it to a "show" status..
Old 05-15-2011, 08:35 PM
cencalc6 cencalc6 is offline
Great build
Old 05-20-2011, 09:39 PM
Tuske427's Avatar
Default rear window drainage
Thank you!
This afternoon I completed a couple of small projects. I welded in the inner seat belt brackets to the trans tunnel. I also built some drainage tubes for the rear window channel. As we all know these first gens like to collect water at the base of the rear windows so I added some drainage tubes to the corners to allow water to drip through. I'll attach rubber tubes to these and have them exit through the wheel wells (when installed)
Old 05-22-2011, 09:05 PM
Tuske427's Avatar
Default front wheels
I had a couple of hours today so I borrowed my old wheels from my neighbor, Brett, to see how they would fit on my car. Well, they didn't. It's a good thing I am planning to use a different wheel. I was thinking about the American Racing 200s wheel (17x9.5 front) and (17x11 rear). I like the retro look, but I need to talk to someone who knows about these wheels. If they're crap or won't clear the brakes I want then I'll need to keep looking. But this was a good lesson to see and determine the sizes that will fit and what modifications I'll need to do to make these work. I knew that I would need to modify/ rebuild the inner fenders but it looks like I'll be notching the frame rails, too. Hope to get to that next weekend...
Old 05-22-2011, 09:10 PM
When I was a kid I wished I could fit tires like that on my Z/28 in the rear never mine the front.
Old 05-22-2011, 09:42 PM
Tuske427's Avatar
They'll fit your car now, yes?
BTW- those pics I posted today are the incorrect offset. The wheels would barely turn like that. I had to space them out a good 2" or so. They also tuck in way too far, imo.
