Closed Thread
Old 06-19-2011, 04:58 PM
coolwelder62's Avatar
Todd, Look's like might in good hand's W/Rodger.
  #2222
Old 06-19-2011, 05:20 PM
nvmyss nvmyss is offline
I agree with Curtis, contact Russ.
Adam
69 Chevelle SS 396 < --Sold
67 Camaro
06 2500 Dodge Ram Diesel
93 Beretta GTZ
04 S60R ..Gone
  #2223
Old 06-19-2011, 06:35 PM
frojoe's Avatar
frojoe frojoe is offline
Originally Posted by ironworks View Post
The frame side of the weld acts like a huge heatsink and depending on how the weld was struck, the speed that the bead was laid, and the "tapering off" of the heat at the end of the bead, the localized heat affect zone might have caused the framerail side to be too brittle. The bracket would likely get hotter during welding, and a sharp end of the weld heat might cause the framerail to cool too quickly from an already lower temperature immediately around the weld... if I had to guess. This kind of heat affect zone is usually much more critical/noticeable in aluminum.
I'd say the crack started at the welded-on bung for reasons I stated above and propogated from all the torque from the upper link trying to pull the bracket away.
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
  #2224
Old 06-19-2011, 07:06 PM
There is a major difference in the design of the G-Bar(in my car) and the G-Link that is in Rogers car. The G-Bar has a front crossmember while the G-Link doesn't. Rogers is a severe frame fracture in his first event from my understanding. Mine is a crack after 6000 miles and 20 some races. We all know I don't baby my stuff.
My plan is to have the frame tig welded up and ground flat, then weld on a small diamond shape 1/8" steel bracket on the outside of the frame along with welding it to the cradle. Russ welded up my exhaust at ATS so I have nothing but confidence in him. Problem is, last time I called him, he never called me back.
  #2225
Old 06-19-2011, 07:41 PM
Wow this has me rethinking the plan to go with the G-link. I'll definitely be hitting the strip on occasion with some sticky tires and I'd prefer my framerails stay intact. One of the things I liked about the G-link was that it seemed to be the stronger setup of the popular 4-link setups available. Maybe it's worth opening up the outside rail and welding in some plate to strengthen that area of the rail as part of the install.
John
'71 Nova (Build thread)
FFR Roadster
  #2226
Old 06-19-2011, 08:00 PM
Isn't Dan Holohan working on your Nova.I belive he is one of the best fabricator's to ever turn on a welder.Ask Dan how he would install your rear suspension.
  #2227
Old 06-19-2011, 08:16 PM
It's not designed to be WELDED in --- I think it's a BOLT IN design -- which - if it was bolted in - you wouldn't have the embrittlement associated with the welding.
If it was welded in properly -- i.e., with some fish plating and re-inforcement it would probably be just fine.
  #2228
Old 06-19-2011, 09:22 PM
In Roger's case, I'm not sure embrittelment argument holds up. It's not close to the fracture line like mine. In these triangulated 4 links, the uppers bars take extreme force keeping the rear end centered. With the front crossmember like mine has, both frame rails get loaded. Without, only one really gets loaded which isn't ideal.
Greg is right, they were both designed to be bolted in the chassis. As usual, we all think we know better than the engineer that designed the system. I'm not ready to say that bolting it in would have netted me better results at this point. 1/16" sheetmetal would take a beating either way.
  #2229
Old 06-19-2011, 09:40 PM
Track Junky's Avatar
Holy Shiz-nit!! Nice work torque king .
Gaetano Cosentino
  #2230
Old 06-20-2011, 11:24 AM
syborg tt's Avatar
Okay so I now have a question
What about using the bolts & panel bonding glue ( fusor ) instead of welding ??
marty-mj
Closed Thread
