Old 07-11-2011, 10:08 AM
jag4902 jag4902 is offline
Default HELP-Which Headers fit HEIDTS Pro-G with Small block?
Need some help with which headers will fit 69 Camaro with Heidts Pro-G subframe.
I have tried several but they are hitting the steering hook-up.
The Number 1 ex. pipe hit the lower steering joint and shaft.
I hate to beat these new headers to make them fit.
Small-block engine / manaul trans.
I already called Heidts.They are designing headers at this time,
still aways off
before they are done.
Old 07-12-2011, 06:02 PM
70rs's Avatar
70rs 70rs is offline
Did you ask them which headers they designed it around to begin with? Its very similar to the TCI sub. Maybe cross check dimensions from thier frame to yours? I know its a long shot but it might get you some info to use.
Eric
Old 07-18-2011, 04:10 AM
Default Headers
According to Heidts, Dynatech is designing headers for them for this car. But they are months away from being ready.
Old 07-19-2011, 10:55 AM
Heidts_Sales's Avatar
Heidts_Sales Heidts_Sales is offline
Default headers for HEIDTS Camaro Pro-G
The small block header that would work is HEDMAN number 68460 for 82-92 Camaro small block
Old 07-19-2011, 03:49 PM
tmadden's Avatar
tmadden tmadden is offline
Frank at Prodigy hit it right the first time with a set of Stainless Works on my LS2
Old 07-21-2011, 06:39 AM
Default Headers
Will contact Frank and ask for input.
Thnks.
Old 07-21-2011, 11:17 AM
70rs's Avatar
Did you see this from Heidts?
$175.00 from Summit. In stock.
Eric
Old 07-23-2011, 07:17 AM
Default Headers
I will look at the ceremic-coated headers.
Thanks.
Old 07-30-2011, 02:26 PM
70rs's Avatar
Thanks.
Did you have any luck with the headers yet?
Eric
