Old 07-16-2011, 06:06 AM
W84IT's Avatar
W84IT W84IT is offline
Default test
Thanks Phil,
Old 07-25-2011, 04:08 PM
W84IT's Avatar
Default Making progress
Completed work:
Steering Installed
Brake and clutch master cylinders installed and firewall smoothed around them
Trans tunnel completed
Fabricated new raised drive shaft tunnel and installed
Installed brake/clutch pedal and gas pedal
Radiator mounted to core support
Fenders and core support mounted to chassis
[IMG][/IMG]
Old 07-25-2011, 04:15 PM
Nice. What radiator is that?
John
'71 Nova (Build thread)
FFR Roadster
Old 07-25-2011, 05:02 PM
coolwelder62's Avatar
Keep's getting better W/every post. Scott M.
Old 07-25-2011, 06:27 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Great stuff.
Old 08-01-2011, 05:32 PM
W84IT's Avatar
Here are a couple of more shots.
[IMG][/IMG]
Old 08-01-2011, 06:41 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
It is an Autorad Radiator
www.roadstershop.com
Old 08-02-2011, 09:56 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
Always great stuff from you guys!
TJ Ragucci
http://www.northeastrodrun.com/
Old 08-02-2011, 10:45 PM
garickman garickman is offline
[IMG][/IMG]
What do people use to get the uniformed smooth look when sanding to the bare metal?
Old 08-03-2011, 09:10 AM
Supporting Vendor
RoadsterShop.com
It takes some skill on both the welding and metal finishing side. The quick answer is that you have to be able to weld the panels with minimal warping or distortion. Then knock the welds down with a grinder with out getting into the metal around it. We then do a lot of hammer and dolly work to make sure that all surfaces are even and uniform before final grinding. We step down the grit getting finer and finer and then finish it with a DA and then a red scuff pad by hand.
