Old 06-21-2011, 11:09 AM
syborg tt's Avatar
Originally Posted by 70rs View Post
Marty, I am interested in the battery jewelry. Can you pm me $$info when you have time please?
Also, I listed the part# for those headers in the other thread. and sent you a pm too.
pm sent
marty-mj
Old 07-07-2011, 12:03 AM
formula98's Avatar
formula98 formula98 is offline
Default Battery Tray
Originally Posted by Syborg TT
If there is enough interest I will make a few extra for people.
Pictures hosted by www.garagescene.net
I'm in for 2 of them..... Here are a few shots of the tray in my Z28
It fits very nice!
Ron
1970 RSX Z28
Old 07-25-2011, 03:44 PM
syborg tt's Avatar
2nd Chance Camaro - Installing the Ride Tech Front Suspension
Installing the Ride Tech Front Suspension & DEI Boom Mat
Posted: July 25, 11 www.2ndchancecamaro.com
Good Morning all,
Steady working on the car just haven't had the time to post up pictures it's hard to believe how far behind I am on updates.
Some of the little things you need to do when installing the Ride Tech lower controls arms. You are going to have to trim the rubber grease boot so they can tuck nicely in the lower arm ball joint pocket. Ride-Tech did a nice job planning for this.
Once Installed they look perfect.
The upper arm went on just as easy as the lower arm on the passenger side.
I wanted to know what the ride height would be once I put the car back on the ground. So I asked Dennis over High Speed Welding made me up a couple mock up shock rods so I could set the ride height.
When I went to install the lower control arm on the drivers side the bushing didn't fit in the frame. Most likely because the car still had it's original bushings and they just kept tightening the bolt to take up slack in the worn out bushings.
This is a cool little tool I made up years ago when working on Syborg. Just slip it in and open up the bolts evenly and it will do a good job of keeping everything square. Just make sure the washers are large enough to distribute the pressure.
Make sure you opened the gap up at least a 1/4" further then you need as the metal will spring back.
Lower control arm fit right in after I spread the lower control arm pocket
Funny in the old days ( late 80's - early 90's ) I would have got out the dead blow hammer and just beat it in. Most likely damaging the paint, the bolts and my skin. However hitting things with a hammer sometimes just make you feel better.
Checking the fully compressed height - wow is the car going to be low.
When I was at the Good Guys Columbus show I headed over to DEI to check out there new sound & heat insulation product. Talk about a full line of stuff at 1/2 the cost of other guys. I can't wait to start installing this stuff.
www.boommat.com
marty-mj
Old 07-25-2011, 05:35 PM
coolwelder62's Avatar
Marty,that's great you are making progress on your project.The ride tech componet's are great pcs.
Old 07-25-2011, 07:45 PM
Rick D's Avatar
Rick D Rick D is offline
Talking
Looken good Marty, nice to see you moving along. Now can you please resize your pictures they don't fit on my laptop screen
Rick
Old 07-25-2011, 09:35 PM
syborg tt's Avatar
lol - just call them super sized.
marty-mj
Old 07-26-2011, 07:52 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Nice progress my friend! Are you going to run stock spindles?
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 07-26-2011, 07:58 AM
syborg tt's Avatar
Yes at this time - unless you have a suggestions
marty-mj
Old 07-26-2011, 08:43 AM
jy211's Avatar
jy211 jy211 is offline
It fits very nice!
crap! that looks like it'd fit in my 56' chevy nicely...
nice pink jack stands BTW....my wife would approve of them
Old 07-26-2011, 01:27 PM
OLDFLM's Avatar
Not at this time - unless you have a suggestions
Luke (L&H) was suppose to be building a set for second gens... didn't see where he's had time to produce them yet though... that's the only link in my suspension I still want to upgrade at some point.
Something stronger than 40 year old spindles that will bolt up easily and accept C5/C6 brakes... Anybody making upgraded aftermarket 2nd gen spindles yet? Buehler? Buehler?? Buehler???
Maybe Gonzo could knock us out a couple sets in his spare time?
FREEDOMBIRD
