Old 09-14-2011, 12:31 PM
6carmello8 6carmello8 is offline
Default QA-1 lowering question
Hi guys,
I posted a thread earlier last month about how to further lower my coilovers and never really got a straight answer and had the time to really look into it but I think I figured it out.
I stated that I have 1/2" thread left from the bottom thinking that lowering the spring will lower the car but I have a feeling that raising the spring will compress the spring, thus shortening it, ultimately lowering the car.
Please confirm!
Old 09-14-2011, 02:18 PM
Bryce Bryce is offline
You have it backwards.
The spring rate is fixed and the weight of the car is fixed.
Since F=kX x is always the same.
F is the weight
k is the spring rate
x is the compressed spring length at that weight.
The only way to lower your car is to get a shorter spring, a softer spring rate or lowering your nut that holds the bottom of the spring.
Good luck.
Old 09-14-2011, 03:16 PM
F is the weight
Good luck.
Thanks for this info. Do you know if QA-1 makes a shorter spring than the spring the GM coilover conversion comes with? I'm guessing they do...
