Old 08-26-2011, 01:25 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
Default better Pics
Nothing new just better Pics, I have to finish the passenger toe board and install the driver still. I took the last few days off from the car because of a memorial for some fallen friends.... and now I'm waiting on this Hurricane to pass to get some more work done.
I had to move everything inside including all the scraps from the original floor. I have the chainsaw on standby for this storm.
I sold my silverado I kept my wheels if they wont work on the 2010 I'll be getting rid of them... if anyone is interested feel free to PM me.
Old 10-09-2011, 02:26 PM
Default New floor install
I got the one piece floor in and much to my suprise the subframe bolted right up and everything went well on that end.
Yesterday I cut out the trunk pan, the more I looked at the tailpan the more I knew it needed to be replaced aswell. I saved myself about 100 spotwelds by just cutting it out as one piece. The previous owner did a pretty terrible job doing Qtr skins which left me 5 spot welds on each side of the tail pan, and a huge discusting bead weld on the bottom of the qtr I needed to cut.
I started to mock everything up in the trunk area, I still need to make some fill plates for the trunk floor. I am waiting on a new outer wheelhouses, tailpan and inner panel. I am still debating if I want to replace the Qtrs while I'm in there. I dont do it now I think I will kick myself later.
Has anyone had any issues with Qtrs from National Parts Depot? I got my floors there figured I would use them again.
well on to the pictures
Old 10-09-2011, 03:04 PM
orangevert's Avatar
orangevert orangevert is offline
Originally Posted by johnnymac46 View Post
I took all of the glass out, and got the firewall stripped down yesterday. Thanks a lot to Frank from Prodigy Customs, he saved me a lot of time and headache with a quick tip on the E-brake cable. I hope to get it off to Media in the next week or so. from the looks of things im going to need to replace the whole floor pan, and do some work around the rear window
Care to share how to get The E-brake cable out?
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 10-09-2011, 03:09 PM
If I remember right slide the box end of a 9/16 wrench over the end of it and pull the cable. It sounded too easy but worked after a couple trys.
Old 10-09-2011, 10:22 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Good progress and metal work. I wonder where you ordered the toe boards and floorpan from as I also need to replace the toe boards on floors on both sides..
72 Camaro RS:SOLD
68 Camaro:
Old 10-10-2011, 12:31 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Nice progress. It's starting to look like a car again.
Curtis
Old 10-10-2011, 06:48 PM
The floor fit pretty well.
I wasnt that impressed with the toeboards the stamps werent all that great, which didnt matter all that much as I didnt use the whole piece anyway. I still havent finished grinding the welds yet.
Has anyone used NPD quarters?
Old 10-10-2011, 06:49 PM
Thank you, I'm slowly learning as I go.
Old 11-02-2011, 04:57 PM
Spiffav8's Avatar
Lateral-g Moderator
John,
It's been almost a month since the last update. Got anything new for us?
Oh...and clean out your mail box.
Curtis
Old 11-02-2011, 05:50 PM
Cleaned out.....
I'll update this weekend when I get home
