Old 01-26-2012, 07:07 PM
That's going to be one bad ass project! Keep it up.
Old 01-27-2012, 07:58 AM
xtreme's Avatar
xtreme xtreme is offline
Thanks Buddy! From your posts it seems to be that your a big CUDA fan also! Trust me I wont let you down with this one! You may just have to give me 10 years to do it haha
Old 02-01-2012, 04:35 PM
xtreme's Avatar
Another new parts update! 60mm roller cam core, another set of engine block off plates so that when I start smoothing the sand casting and blasting I can keep the engine clean and don't have to damage the Evernham plates I already have!
Clevite coated rod bearings, Clevite coated main bearings, another set of billet oil sprayers so now Ill have two sets. New Damper ring and o ring rebuild,
Front cam seal, Front crank seal, rear crank split seal cometic, Valve train Organizing tray, New 60mm roller cam bearings. Brand mew R5 MSD Pro Billet Distributor Dual Pickup.
Old 02-10-2012, 07:55 PM
xtreme's Avatar
Hey guys wanted to update you on my father's Tube chassis Duster drag car! His R3 440 stroker is finally built and made 780hp on the dyno on gas. Hes hoping to creep into the 800s with alcohol. Should be a wild ride and my first attempt at a drag car!
Old 02-11-2012, 07:18 AM
millerman340's Avatar
millerman340 millerman340 is offline
Sweetness! I like the p7 stuff but I'm a sucker for a well built R3..
Old 02-11-2012, 05:28 PM
xtreme's Avatar
I agree with you on that! I searched some old threads when you were looking to do a turbo on the r5 stuff! Did you figure anything else out?
Old 02-11-2012, 05:40 PM
No, but I se e a few people have bootsed the p7 with success. I'll stick with the w9's.. There fine for me!
Old 02-12-2012, 02:24 PM
xtreme's Avatar
Yah as long as I put together the right combination, everthing should be fine! Thanks anyways!
Old 02-15-2012, 05:38 PM
xtreme's Avatar
Hey guys I already sold one pan, I have two left in the for sale section! Wanted to post up better pics of the quality of these for you to admire! Updates soon!
Old 02-21-2012, 03:39 PM
xtreme's Avatar
Better pics!
