Old 02-08-2012, 07:43 AM
SicMonte's Avatar
SicMonte SicMonte is offline
Put a zirk in that threaded hole that looks to be empty on the side in the one photo.... that could be your source of leaking.
That threaded hole has an allen set screw in it. It is leaking out of the zerk fitting that faces down.
Old 02-08-2012, 07:51 AM
ah ha.... I couldn't tell from the photos... that one pic looks like a threaded hole.
Old 02-08-2012, 09:28 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
Mine drip too. I put small rubber caps on the grease fittings and that solved the issue. I have to keep my grease gun in a plastic bag in the tool cabinet as it tends to drip also.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 02-08-2012, 12:32 PM
SicMonte's Avatar
Great idea...I never thought of that!!!!!!
Old 02-13-2012, 08:14 AM
Marcus SC&C's Avatar
Grease zerks shouldn`t leak, they have a check ball for that. If they do just replace them. Grease, especially non synthetic grease can liquify over time especially when exposed to high heat. See how close it the BJ is to the sometimes screaming hot brake rotors? David`s right, just grease it until only clean, thick grease comes out and carry on. Mark SC&C
