Old 02-10-2005, 08:03 PM
Originally Posted by slownova
thats a pretty car. is the subframe in the car still? or what does the cage go to?
The front subframe is out and over here:
I have a 6 point cage in the car, tied into the rear frame rails in the trunk and the welded in DSE frame connectors, and to a plate on the floor up front by the kick panels. The front subframe and frame connectors bolt together with 6 bolts as I wanted to keep the subframe removeable.
Old 02-10-2005, 08:38 PM
slownova slownova is offline
wow man thats gonna be a clean clean car when your done. i got a couple questions for you tho...
on your LT1, does it have the gear for the distrubitor on the cam? or did you order the cam that way...?
as for bolting a 4L80E to the LT1, will anyone bolt up to it? or did you have to get one out of a pre-LS1 truck?
any way that car is gonna be K-I-L-L-E-R...
Old 02-10-2005, 09:05 PM
Blown353 Blown353 is offline
Nice! Are you going to be around this weekend? I want to come up and test how well drool rolls off of it.
I think Pasqual may be getting a certain 69 Chevelle to work on later this year...
1969 Chevelle
Old 02-10-2005, 09:08 PM
The LT1's have a dist gear on the cams just like a regular small block; they use the gear to drive the oil pump with a little stub shaft bolted under the intake manifold.
The trans is a standard Chevy V8 bellhousing.
Old 02-10-2005, 09:09 PM
I'll be around, head on up!
Old 02-10-2005, 11:10 PM
Musclerodz's Avatar
That looks awesome Jody! I love to look at a Black car done right.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-10-2005, 11:37 PM
JamesD's Avatar
JamesD JamesD is offline
looks good, although it will look even better when it's done.
Old 02-11-2005, 01:38 AM
Default ahhhh
hey Jody? you sure its not wet still ? looks nice. Did Pas do the roll bar too? can't wait to see this one. Vin
Old 02-11-2005, 06:04 AM
68protouring454's Avatar
Default black
kickass jody, definetely came out real nice, **** that perfect, tried a test panel with the semi gloss clear?? you doing the stripe at your shop??
]again awesome work, looks killer
jake
Old 02-11-2005, 07:40 AM
MaxHarvard's Avatar
sweet god, thats nice!
