Old 04-01-2012, 12:21 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Painting aluminum block and heads (LS3). What to use?
I've tried searching on several different forums, but there is not a whole lot of info on guys painting their LS engines. I want to paint mine while it's still clean. The two options that I'm looking at is either painting it with POR15 and then top coating it with their engine enamel paint. I've read lots of good reviews on the POR15 engine paint and have used their products quite a bit so I know what's required to make it stick. So far I'm really impressed with their stuff. The other option I'm looking at is using Duplicolor's engine primer followed up with their engine paint with ceramic. I want to paint it aluminum color to make it look stock, but to avoid any ugly oxidize build up.
What have you guys used to paint your aluminum motors and how has it stood up? If you did it again, would you use the same stuff?
Thanks in advance.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 04-01-2012, 05:11 PM
almcbri's Avatar
almcbri almcbri is offline
I painted mine with duplicolor engine primer and paint.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 04-01-2012, 06:05 PM
Merlin Merlin is offline
Heat dispersion ceramic coating to help shed away heat. I had an intake manifold coated with a black heat shedding coating. After an auto-x run, one could touch the intake as it would be cool to the touch.
This is what I used. http://www.techlinecoatings.com/arti...an_Article.htm
Cliff
369 CP Chevelle
Old 04-20-2012, 01:55 PM
jeff s's Avatar
jeff s jeff s is offline
Supporting Vendor
We've had success simply using a high quality enamel, like you'd use on the body of the car. The High-temp POR15 might be overkill since your block is already clean.
You should be more than fine with a nice high-temp enamel.
Thanks,
Jeff Schwartz
SchwartzPerformance
Website : Facebook : Twitter
Old 04-21-2012, 03:28 PM
onefast70elco's Avatar
onefast70elco onefast70elco is offline
i agree with jeff!
Old 04-21-2012, 04:37 PM
John510's Avatar
John510 John510 is offline
Dupli-Color in a rattle can works good. Are you changing colors of the motor?
[SIGPIC][/SIGPIC]
Old 04-21-2012, 10:11 PM
scherp69's Avatar
Thanks for all the suggestions guys. I know the POR15 was overkill, but I ended up using it. I painted it with two coats of silver POR15 and then their engine enamel. Very happy with the color of it now. I also painted the transmission.
John...yeah I wanted to get away from the dull grey of the block. I prefer the silver aluminum look than the dull dark grey. I also wanted to paint the block now while it was still new and didn't have to spend a bunch of time cleaning it. This way I won't have to worry about the aluminum oxidizing. The color now is more silver. I'll take some pics in the next couple days and post some.
Mike
New Gen Splitters
LS3 and TKO600
Old 04-30-2012, 08:27 AM
kainedogg's Avatar
kainedogg kainedogg is offline
I would like to see those pics as well. Debating what to use to paint my transmission.
Old 05-14-2012, 08:29 PM
timpala62 timpala62 is offline
i used eastwood's paint with activator with a self etching primer.
Old 05-15-2012, 04:41 PM
scherp69's Avatar
Sorry for the delay, here's a couple pics of what the color looks like. This is the POR15 engine coat and the color is aluminum. I started with two coats of silver POR15.
Here's the before, more of a dull gray
After
Overall I'm very happy with the color. The only thing I'm not happy with was when I was putting it on, I thought I was putting it on with a light coat. Apparently it wasn't as light as I thought and started to run a bit. I tried to brush out the runs, but it ended up leaving some brush marks on the front of the heads. A friend of mine looked at it and really couldn't tell until I pointed it out, but it's one of those things that I know is there. Oh well, hopefully once everything's on the motor it will hide most of it.
Here's what I was talking about on the front of the heads
Mike
New Gen Splitters
LS3 and TKO600
