Old 04-12-2012, 06:31 AM
CornHusker4Life's Avatar
CornHusker4Life CornHusker4Life is offline
Default 350 Longblock with AFR Heads and Roller Cam
http://atlanta.craigslist.org/nat/pts/2952680512.html (pictures)
https://www.youtube.com/watch?v=lnk6Vvv9bUk (Engine Running)
We have a low mileage (less than 1,000 miles) 350 Chevy engine, with 4 bolt main caps and a high-nickel block. The engine is a low mileage take-out from a customer car that is getting an LS2 swap. The heads are Airflow Research (AFR) 195s, and the cam is a retrofit hydraulic roller from Lunati. Lift is .571, duration is around 230-240. Has aluminum roller rockers, chrome oil pan and timing cover, chrome water pump (short style), chrome 1-wire high output alternator, chrome alternator brackets, chromed aluminum ball milled valve covers, air cleaner, and wire looms, aluminum pullies for crank, water pump, and power steering; power steering pump and bracket (painted), stock style points distributor with Accel electronic conversion, chromed coil and bracket, plug wires, Hedman silver coated headers (fit most GM, designed for '67-9 Camaro/'68-'74 Nova; scratched up but not rusty), stock style flexplate. This engine is complete, minus the intake and carb. The engine is pulled, and ready to go. $3000 OBO. Engine can be seen/picked up at Bulldawg Musclecars, 4666 S Main Street, Acworth, GA 30101.
770.975.8980
Old 04-19-2012, 06:43 AM
REDUCED PRICE TO $2800 O.B.O
Old 04-19-2012, 06:51 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
If only I was still in Warner Robins! GLWS!
Ty Ingle, USAF Retired
FREEDOMBIRD
