Old 04-25-2012, 10:45 PM
FETorino's Avatar
FETorino FETorino is offline
Default What are you running for a driveshaft
Since the driveline is all custom I need to start looking for a shaft that will handle the hp and torque of my FE and the sustained rpm.
So for 700hp and 150+mph what do you run for a driveshaft. AL, steel, CF?
Anyone use these guys?
http://www.driveshaftshop.com/#
How about inland empire
http://www.iedls.com/
Anyone have any good or bad driveshaft vendor stories to share?
Rob in SoCal
Old 04-25-2012, 11:03 PM
Ron in SoCal's Avatar
Both companies are good. 3 /12" Al should do I think. But what do I know...
(don't anwser that!)
Ron in SoCal
69 Camaro in progress
Old 04-25-2012, 11:15 PM
Ron, I think he might need larger than 1/4" (=3/12")
Old 04-25-2012, 11:18 PM
FETorino's Avatar
But the 1/4" is so much lighter.......
Rob in SoCal
Old 04-25-2012, 11:23 PM
Yer both right!
Ron in SoCal
Old 04-25-2012, 11:31 PM
Sieg's Avatar
Sieg Sieg is offline
Hurst Drivelines used Inland as the supplier for my conversion. They exceeded all expectations. I had the driveline within 7 calendar days of submitting my measurements.
Old 04-25-2012, 11:33 PM
We all need banned and HELP. I'm running a 3.5" Aluminum from Inland and it's hanging in there fine so far.
Old 04-26-2012, 11:06 AM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
I run a 4" Carbon Fiber driveshaft from Mark Williams. Super light, less high rpm vibration and stronger than aluminum. One good advatange (hopefully it never happens) is that if it fails, then it will shatter rather than poke threw the floor. It's rated for drag launches and high driveline rpms.
Old 04-26-2012, 12:12 PM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Inland Empire Driveline
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 04-26-2012, 12:14 PM
dj3 dj3 is offline
Dennys, you ever break it they will replace for free and they will shorten it for free.
