Old 06-23-2012, 02:50 PM
MoparCar MoparCar is offline
Great set up! I too would love their 221 TIG. I've only heard great things about HTP and would be my first choice in an inverter TIG for the price. At least a grand less than a Miller Dynasty 200.
Let us know how it goes..
Wes
Old 06-23-2012, 08:26 PM
If you can gas weld you can TIG.... exact same hand movements except you don't move the torch in a small circle - you step forward and back - dip on the backstroke - move the puddle forward - back up the torch and dip... it's just a hand dance.
Old 06-23-2012, 09:14 PM
Sieg's Avatar
Sieg Sieg is offline
Wes
Thanks Wes, I'll keep you updated.
Thanks for the tips, I'm looking forward to experimenting with puddle movement. Starting with scraps of steel, aluminum, and stainless sheet.
Hopefully I catch on after a few hours of experimentation.
Just finished installing a dedicated 50a 250V circuit in garage for the equipment so I'll be ready to roll tomorrow afternoon.
It will be nice to have a MIG with horsepower for a change and a TIG to produce artwork quality beads........sadly (and hopefully) I won't be able to blame mediocre welds on the equipment anymore.
Old 06-27-2012, 01:27 PM
Sieg's Avatar
Last night was the first night of practice........
You left out the step: over to the bench to re-grind the tungsten. It took the dog a few re-grinds before he figured out I mad at myself not him.
Found a $30 3" bench grinder at Harbor Freight that works decent, hopefully I can find a finer wheel for it. Quiet and smooth........so far.
Old 06-27-2012, 02:27 PM
Oh trust me -- you'll be doing a LOT of tungsten pointing!
Are you that old - or do you just have that many people in the shop - that you had to sticky note the grinder?
Here's what I do on all my tungsten --- I bite the bullet and sharpen them all - all sizes - all types.... then when I FOU I just toss it in the drawer and grab another.... when I have a few I point 'em.
The real key to TIG is being able to SEE..... and a one lens helmet don't cut it... pee away another chunk of dough and get yourself a real helmet with adjustment from about 5 to 12+.... 'cause when you're doing thin stuff and only using 30 amps -- ya got to be able to see!
http://www.amazon.com/Sperian-Optrel...832387&sr=1-80
Old 06-27-2012, 02:30 PM
Also --- please where a particulate mask when grinding tungsten....
AND --- Never clean ANYTHING with CHLORINATED ANYTHING.... if you use brake cleaner - use NON-Chlorinated....
Denatured alcohol works well.
2 KEYs TO TIG.... CLEAN CLEAN CLEAN CLEAN.... and then be sure it's CLEAN and TIGHT fit up.
Old 06-27-2012, 10:28 PM
Sieg's Avatar
Especially at my age!
I like that strategy, though the cool down period after contaminating another tungsten isn't a bad thing.
Thanks to your previous posts Optrel, my current helmet goes down to 9 and I've been running 35-80 amps and visibility isn't too bad surprisingly. The same helmet impairs vision to a degree when MIG welding.
It doesn't qualify for Prime, WTF!!!
Might be worth it since a friend told me tonight that I'm no good unless I can TIG beer cans together end to end.
Thank you
Old 06-28-2012, 04:44 AM
Any pictures of your HTP equipment? I assuming it has arrived?
Wes
Old 06-28-2012, 11:16 AM
Sieg's Avatar
Wes
https://lateral-g.net/forums/show...9&postcount=20
Old 06-30-2012, 08:21 AM
Okay - Now let's see your little stack of dimes!
