Old 07-01-2012, 04:13 PM
J-440's Avatar
J-440 J-440 is offline
Default FAST injectors...pulse width?
I have a 440na with a 2000cfm throttle body with 83lb. injectors and 8.5 comp ratio. I realize this is overkill for a NA motor but the blower will be going on in a few months but I want to drive the car now!! An EFI tuner has informed me that with the current setup I will destroy the motor because of excessive fuel wash. Ok I agree...overkill. But with the adjustability with the FAST XFI can't I tune the pulse width of the injectors to make the car run?
68 Charger, 440SC, EFI, 6-speed
Old 07-02-2012, 12:30 AM
manny z manny z is offline
Default FI info
Does your FI system come with a star up tune? It should. I would like to find out some of this info also since I am running a bigblock with a procharger, that more then likely I will be converting to FI.
Old 07-02-2012, 03:29 AM
J-440's Avatar
Yes there are about 25 different settings for different engine types that are pre-programmed into the system. I found my closest one and tweeked it a little. Haven't gotten the car running yet because of the above concerns.
Old 07-02-2012, 07:08 AM
there is a minimum amount of time (pulsewidth) that it takes an injector to open/close. If an injector is too large it can cause idle issues as you lose the resolution when you try to get the pulsewidth numbers too small to get the proper a/f. In other words, you can only get the pulsewidth so low.
With that said, I've run bigger injectors than that without issue at idle or anywhere else. Although they were forced induction setups, idle is the problem a large injector usually has the most problem with, and a naturally aspirated or forced induction setup are basically the same there and mine had zero issues. Make sure you boost reference the regulator, it will help at idle by dropping the fuel pressure a bit with the vacuum line installed. My last setup was 75# injectors on a small block with a stock camshaft, idling at 650 rpm and 18" of vacuum. Ran perfect.
Old 07-03-2012, 03:36 AM
J-440's Avatar
Thanks for the help guys. FAST just told me that the injectors are just way too big and no matter how low I set the pulse width, too much fuel wash will occur. Not a good thing. Ah well, I'll just wait a few more months until the blower arrives.
Old 07-03-2012, 06:37 AM
supremeefi supremeefi is offline
What's the projected output? 83's will handle over 800hp.
Are you running batch or sequential?
Mark
Engine builder and tuner.
Old 07-03-2012, 02:44 PM
64duece 64duece is offline
If it's a sequential system, they should be able to idle without issues. The map may be skewed towards the low end vs something that's using the injector but, should work.
Batch/Bank to Bank is different story, they'd be abit much to work at idle, low speed operation.
Dennis
Moore Racecraft
Old 07-03-2012, 06:34 PM
J-440's Avatar
I'm shooting for 800. But the tech guys all said that the 83lbers are too big for an 8.5comp naturally aspirated 440...now matter how low the pulse width. But then again, the s-charger is pushing a certain amount of air even at 600rpm. That's not a lot of air but yet it's a ton of fuel? The FAST guys were real serious when they told me no.
Old 07-03-2012, 06:38 PM
J-440's Avatar
Oh yeah,I'm running sequential. Still learning about this stuff. Bank to bank is when one side fires then the other and is not as controllable as sequential?
Old 07-03-2012, 07:25 PM
at idle I don't see how the EFI or engine even knows there is a blower. There would be some extra pressure in front of the throttle body, but the engine wouldn't see that; in other words, it would act just like N/A. I'm amazed my 95's idled perfectly with bank to bank......................
